1Powering On the Timer:
- Battery Charging:
- Connect the USB-C cable to the timer.
- Plug the other end of the cable into a USB power source.
- A charging indicator may light up, signaling that charging is underway.
- Allow the battery to fully charge before first use.
- Powering On the Timer:
- Use the On/Off 433MHz remote to turn on the timer.
- You should see the LED display light up and hear a beep, indicating the device is powered on.
- Battery Charging:
2Programming the Countdown Timer
- Entering Programming Mode:
- Press the 'A' key on the keypad to enter countdown timer programming mode.
- The LED display should be clear, indicating you can start entering the duration.
- Entering Duration:
- Enter the desired duration using the keypad.
- Input format: HHMMSSXX (Hours, Minutes, Seconds, Hundredths of a second).
- For example, to set a countdown for 1 hour, 30 minutes, and 45 seconds, type '01304500'.
- Starting the Countdown:
- Press the 'D' key to confirm the duration and start the countdown.
- The LED display will begin counting down the programmed time.
3Uploading Other Codes
- Preparation:
- Ensure that the timer is turned on.
- Connect the timer to a computer via the USB-C cable.
- Uploading via Arduino IDE:
- Open the Arduino IDE on your computer.
- Select the correct board type (Arduino Nano Every) and the corresponding serial port in the 'Tools' menu.
- Downloading Codes from GitHub:
- Go to the GitHub page where the codes are hosted (provide URL).
- Download the source code for the project (countdown timer, clock, stopwatch, etc.).
- Unzip the downloaded files if necessary.
- Opening and Uploading the Code:
- Open the file of the code you want to upload in the Arduino IDE.
- Review and make any necessary modifications to the code.
- Click the 'Upload' button to load the code onto your timer.
- Once uploading is complete, disconnect the timer from the computer.
- Testing the New Code:
- Test the features of the new code to ensure it functions as expected.
- Preparation:
Foxtek
