No more missed doorbell rings while working with headphones! Meet ESPBell-Max and ESPBell-Lite Smart intercom and doorbell IoT modules. These devices seamlessly integrate with Home Assistant and ESPHome, providing interactive notifications 🔔 that keep you updated about visitors. And the cherry on top? You can directly open the door from the notification - simply tap "Open Door" or "Ignore" to dismiss the alert.
Details
Two version is available ESPBell-MAX and LITE, Max is battery-powered, and LITE requires a power supply.
ESPbell is an open-source project so all files for PCB assembly and code are available on GitHub
