Pixo | Dazzling Desk Display
Introducing Pixo, a stunning RGB LED desk matrix that brings mesmerizing rainbow patterns to life! Crafted with a custom-designed PCB, 3D printed components, and powered by an ESP32, Pixo features 163 WS2812B Mini LEDs for a vibrant and enchanting display. Transform your workspace with Pixo's colorful charm and dynamic lighting experience.
Housing.stl
Standard Tesselated Geometry - 265.71 kB - 12/27/2023 at 17:26
Download
Pixo1.dxf
AutoCAD DXF - 36.83 kB - 12/27/2023 at 17:26
Download
Cover.stl
Standard Tesselated Geometry - 29.57 kB - 12/27/2023 at 17:26
Download
Pixo2.dxf
AutoCAD DXF - 2.37 kB - 12/27/2023 at 17:26
Download
View all 6 components
  • 2
    About WS2812B
    The WS2812B Mini is a type of programmable LED that works in a simple and fascinating way. Each tiny LED has a built-in microcontroller, allowing it to be individually controlled. It's like having a little smart light on its own!
    Here's the magic: You can send signals to these LEDs using a device like an ESP32. These signals tell each LED what color to shine, how bright, and when to change. This is possible because of the "OneWire" communication protocol, a simple serial protocol that lets you control multiple WS2812B LEDs in a chain using a single data line. This protocol ensures that each LED interprets the relevant data for its color and brightness accurately. With this technology, you can create all sorts of beautiful and dynamic lighting effects, including the mesmerizing rainbow patterns in the Pixo project.
  • 3
    CAD Design
    I started by creating the shapes for the LED arrangement using Fusion 360. I also designed the outer border of the matrix and saved them as DXF files.
    You can find and download the DXF files from below that I created for your reference.
    After that, I imported these DXF files into EasyEDA, which is the software I used for designing the PCB. This helped me reference the shapes accurately during PCB designing process.
    Using the fundamental tools in Fusion 360, I crafted the enclosure and cover for the LED matrix. If you want to learn basics of Fusion 360 you can have a look at my previous article that explains the Fusion 360 fundamentals.
    You can directly download my design and edit it in Fusion 360 software.
View all 10 instructions
Kevin Roach wrote 01/14/2024 at 18:01 • point
Got it! Thank you!
Kevin Roach wrote 01/14/2024 at 16:20 • point
Has anyone built this? I wanted to build one but can't get the gerber file from the maker.
Mukesh Sankhla wrote 01/14/2024 at 16:26 • point
Hey Kevin can you please check the PCB Design step where there is a direct link to download the gerber and other files from GitHub
