PC-XINU.img
A Pre-built copy for people who don't have time to create their own...
img -
1.41 MB -
01/05/2024 at 04:46
Download
startup
Put this in the XINU directory of the boot disk template. You can customise the colours in a text editor.
startup -
121.00 bytes -
01/05/2024 at 04:45
Download
BOOT DISK TEMPLATE.img
A stripped-down version of the MSDOS 6.22 Boot Disk used for creating the PC-XINU floppy.
img -
1.41 MB -
01/05/2024 at 01:45
Download
slip8250.zip
Unzip this. You will find an executable inside. Put this in the XINU directory of the boot disk template.
x-zip-compressed -
3.71 kB -
01/05/2024 at 01:43
Download
dpmiload.zip
Unzip this. You will find an executable inside. Put this in the XINU directory of the boot disk template. It loads the XINU OS in protected mode.
x-zip-compressed -
10.77 kB -
01/05/2024 at 01:43
Download
dpmi16bi.ovl
Put this in the XINU directory of the boot disk template. It runs XINU in protected mode.
ovl -
59.25 kB -
01/05/2024 at 01:41
Download
xinu79.zip
Unzip this. You will find an executable inside. Put this in the XINU directory of the boot disk template. It is the main file.
x-zip-compressed -
109.46 kB -
01/05/2024 at 01:40
Download
AUTOEXEC.BAT
Replace the autoexec.bat in the boot disk template (included) with this...
bat -
300.00 bytes -
01/05/2024 at 01:36
Download
xinu.bat
bat -
193.00 bytes -
01/05/2024 at 01:35
Download
l3x12.zip
Source code from the website if you want to edit it...
x-zip-compressed -
1.75 MB -
01/05/2024 at 01:34
Download
