Basic Functions
01/05/2024 at 19:55 • 0 commentsI can't think of any organized way to walk through what I did to get to the point I am right now, so I'm just going to put the YAML here and let the comments speak for themselves. I wish the syntax highlighting was nicer, but there it is.
Based on the YAML I found for the M5StickC Plus on the ESPHome devices page:
substitutions: devicename: test-dongle upper_devicename: DONGLE TESTING esphome: name: $devicename platform: ESP32 board: m5stick-c #there are only a few options, and this is the closest platformio_options: upload_speed: 115200 wifi: ssid: !secret wifi_ssid password: !secret wifi_password ap: ssid: $devicename Fallback Hotspot password: !secret wifi_password captive_portal: # Enable logging logger: # Enable Home Assistant API api: encryption: key: "<redacted>" ota: password: "<redacted>" # The older version of this dongle has an AWP192 power management chip, so # the YAML I started with had support for reading the battery voltage # from the PM chip. The AWP192 was also needed to turrn the LCD backlight # on for some reason. The PLUS2 stick doesn't have a power management chip, # so we just read the battery voltage from the ADC on GPIO38 (got that # little tidbit from diving into the schematic.) sensor: - platform: adc pin: GPIO38 # ADC1_CH2 attenuation: 11db # because reasons? update_interval: 60s name: "Battery Voltage" filters: - multiply: 2.0 # Schematic shows a voltage divider with # two 100k resistors feeding GPIO38, so # we multiply by two. Seems to be giving # accurate readings -- or at least reasonable # Built-in 6-axis intertial measurement unit (IMU) that also includes a temperature sensor # Pretty much just pulled this from the ESPHome docs, seems to work well - platform: mpu6886 i2c_id: bus_a address: 0x68 update_interval: 10s accel_x: name: "MPU6886 Accel X" accel_y: name: "MPU6886 Accel Y" accel_z: name: "MPU6886 Accel z" gyro_x: name: "MPU6886 Gyro X" gyro_y: name: "MPU6886 Gyro Y" gyro_z: name: "MPU6886 Gyro z" temperature: name: "MPU6886 Temperature" # Button setup. The dongle has three buttons, this code does useful(ish) # things with them: # Button A (big one on front): Turns off LCD backlight while pressed # Button B (small one on side): Sounds 1000Hz tone while pressed # Button C (other small one): Supposed to turn off the internal LED, # but doesn't work binary_sensor: - platform: gpio pin: number: GPIO37 inverted: true name: ${upper_devicename} Button A on_press: then: - light.turn_on: display_bl on_release: then: - light.turn_off: display_bl - platform: gpio pin: number: GPIO39 inverted: true name: ${upper_devicename} Button B on_press: then: #- light.turn_on: led1 - output.turn_on: buzzer - output.ledc.set_frequency: id: buzzer frequency: "1000Hz" - output.set_level: id: buzzer level: "50%" on_release: then: #- light.turn_off: led1 - output.turn_off: buzzer - platform: gpio pin: number: GPIO35 inverted: true name: ${upper_devicename} Button C on_press: then: - light.turn_on: led1 on_release: then: - light.turn_off: led1 # Built-in LED is on GPIO19. The IR LED is also on the same GPIO. One or # both of them get VERY hot while LEDs are on. light: - platform: monochromatic output: builtin_led name: ${upper_devicename} Led id: led1 - platform: monochromatic output: backlight name: ${upper_devicename} Backlight id: display_bl output: - platform: ledc pin: 19 inverted: true id: builtin_led - platform: ledc # Buzzer is connected to GPIO2, and we pin: 2 # use PWM to control it, hence the ledc inverted: true # platform id: buzzer - platform: ledc # TFT backlight is on GPIO19, ditto PWM pin: 27 inverted: true id: backlight # This block was what was killing the original compile, haven't played # with it yet #remote_transmitter: # - pin: # number: GPIO9 # carrier_duty_percent: 50% # id: internal # From the schematic it looks like the TFT is using SPI spi: clk_pin: GPIO13 mosi_pin: GPIO15 # MMU uses I2C i2c: - id: bus_a sda: GPIO21 scl: GPIO22 scan: True # Get something on the display font: - file: "gfonts://Roboto" id: roboto size: 18 color: - id: my_white red: 100% green: 100% blue: 100% # 1.14 inch, 135*240 Colorful TFT LCD, ST7789v2 display: - platform: st7789v model: TTGO TDisplay 135x240 cs_pin: GPIO5 # Had to change pin assignments dc_pin: GPIO14 reset_pin: GPIO12 rotation: 270 lambda: |- it.print(80, 0, id(roboto), id(my_white), TextAlign::TOP_CENTER, "M5Stick Test"); # Haven't worked on audio yet #i2s_audio: # id: bus_i2s # i2s_lrclk_pin: G26 # i2s_bclk_pin: G0 #microphone: # - platform: i2s_audio # i2s_din_pin: GPIO34 # i2s_audio_id: bus_i2s # adc_type: external # pdm: true # id: mic
