Setting Up the Compute Module 4
01/07/2024 at 09:11 • 0 commentsWe set off building a compute cluster using the Raspberry Pi Compute Module 4 for its smaller form factor and higher customizability.
CM4 with WaverShare's CM4-DUAL-ETH-MINI
Day 1 - 3
5 Jan 2024 - 7 Jan 2024
Set up and Flash the CM4 EMMC (Need to use Legacy Raspberry Pi OS Bullseye)When connecting a WaveShare board with the CM4 don't fret to press hard to make sure it connects properly with an audible click.
Set up ethernet networking
the file
sudo nano /etc/network/interfaces.d/eth0the content
auto eth0 iface eth0 inet dhcp ``` Replace the `dhcp` option with `static`, and add the IP address, netmask, gateway, and DNS server information. For example: #auto eth0 #iface eth0 inet static # address 192.168.1.100 # netmask 255.255.255.0 # gateway 192.168.1.1 # dns-nameservers 180.76.76.76list of DNS servers used Baidu's
the file
sudo nano /etc/resolv.confthe content
nameserver 180.76.76.76
netowrk error even after correct setup -> incompatible router problem
The CM4 didn't work on the Huawei router that came with 中国电信 (ISP) but worked on the newifi router.
router that worked ![]()
router that didn't work After switching the connected router, we were able to successfully ping baidu.com with 45~ ms.
OpenMPI is not OpenMP. OpenMP is for a single device with shared memory while OpenMPI is for multiple devices.
Michael Wang
