1Disassembling the microwave
Important! There is a high-voltage capacitor in the microwave that can be charged, so you need to be careful.
2Throw out the standard mechanical timer
3Using an electric jigsaw, cut out a window for a new display.
Not technologically, not neatly, but true DIY :)
4Glue the display onto the thermal glue
5Glue a piece of PVC on top of the display and screw the Arduino UNO
6Add a relay and connect the wires from the timer to the relay.
As a rule, a mechanical timer equipped with a power regulator has 4 wires. 2 of them are responsible for turning on the turntable, lamp and magnetron (for a common disconnector), 2 more are used to control only the magnetron.
The power adjustment on the mechanical timer is carried out by controlling the operating time of the magnetron.
Therefore, if you want to control the power of the microwave, you need to install 2 relays. One will be responsible for the general activation, the second will be responsible for controlling the magnetron.
I didn't need power control, so I closed the magnetron control contacts between each other and set the relay to short the wires of the general power supply.
7Add the encoder to the old power control knob
I soldered the encoder to the breadboard and made holes in it that match the regular holes in the housing of the microwave oven. Using brass spacers, I set the optimal height so that the handle does not stick out of the case.
8Connect everything to the arduino
9Add an endswitch
If you want the timer to stop when you open the microwave door, either add a separate endstop and connect it to the arduino, or use an optocoupler to connect one of the endstops that are already in the microwave.
10Assemble it
