Hackaday.io Hackaday.io
Sign up Log in
Solid State Tank - Eink wrist watch
Eink wrist watch with custom segmented eink display and sub 500nA consumption in a tank style.
augustoAugusto
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2k views
3 comments
22 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 3
View Gallery
2k
3
22
23
Team (1)
  • augustoAugusto
Join this project's team
  • Blog post 1
  • Blog post 2
hardware
ongoing project
eink WAtch lowpower wristwatch
Related lists
General
Projects to come back to
This project was created on 01/19/2024 and last updated 3 years ago.
Description
Solid State Tank is an Eink wrist watch inspired by CW&T solid state watch.
The watch uses a custom made segmented eink display with half scale DSKY digits.
The consumption is sub 500nA at 3V and the system is powered by a CR1616.
The whole watch is encased in clear epoxy.
Detailed writeups of the build:
https://www.0xam.com/blog/solid-state-tank-part-1-eink-watch-sub-500na3v
https://www.0xam.com/blog/solid-state-tank-part-2-assembling-the-watch
Details
Log In/Sign up to comment
Sign up with Github
OR
robomaniac wrote 01/31/2024 at 22:54 • point
Nice work, I saw more details here
Augusto wrote 01/31/2024 at 17:06 • point
Hi!, Thanks for the comment. I delaminated one e-reader screen (you have to buy old models as newer ones don't delaminate) and then laminated the eink portion to the PCB using heat and UV curable clear epoxy to seal the edges.
More info here: https://www.0xam.com/blog/diy-e-ink-part-1-delaminating-the-screen and https://www.0xam.com/blog/diy-e-ink-part-2-testing-the-screen
David Plass wrote 01/31/2024 at 17:01 • point
Love the DSKY digits! But how'd you make a custom eink display?
Abusing the custom characters of the HD44780 chipset to display some 漢字
Project Owner Contributor
Kanji Clock on Alphanumeric LCD
danielDaniel
Nokia 5110 display as "Game & Watch" lcd Build a nintendo game & watch octopus clone using a nokia lcd and an ATMEL AVR microcontroller
DIY Octopus
thomas-baumThomas Baum
Stack a bunch of transparent OLEDs together and you have yourself a Volumetric Display.
TENEX - Solid State Volumetric OLED Display
sean-hodginsSean Hodgins
https://m.youtube.com/watch?v=9uv1FU-cKg
ALARM KEYPAD CHALLENGE
taurai-mirimiTaurai Mirimi
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Solid State Tank - Eink wrist watch", please tell us the reason.
Send message
Remove Member
