Screenshot 2024-06-09 at 12.27.51 AM.pngOption power button add in. Connect the negative power wire to the location shown and the built in switch will turn on and off the Rak unit.Portable Network Graphics (PNG) - 2.61 MB - 06/09/2024 at 10:28 |
Harbor Pole telescope.stlPole mount for a solo panel type installation. Since the led enclosure is not needed you can get rid of it and use the mounting tabs to mount to a pole with an SMA slot. With this print you do not need to drill a new hole for the antenna wire.https://cad.onshape.com/documents/71b55f121e75b59cc458d217/w/5cb3688ce11b624981d412e3/e/fd68181190950d769c16a475 Standard Tesselated Geometry - 170.30 kB - 06/09/2024 at 10:20 |
Screenshot 2024-01-21 at 1.44.22 PM.pngGraphed battery data. Camel head lines are included 1500mah battery. Green is 2800mah molicelPortable Network Graphics (PNG) - 169.13 kB - 01/21/2024 at 23:47 |
Tavis
