Telescope Mount Controller using PERSEUS-9 Log
01/23/2024 at 12:46 • 0 comments1. The article was first posted on Jan. 21, 2024.
2. Revised on Jan. 23, 2024
Added photo of aluminum materials in process to attachments.
3. Revised on Jan. 25, 2024
Added photo of the crystal oscillation section of the MCT-6 control unit.
4. Revised on Feb. 2, 2024
Added photo of a maximum payload of 15cm F4 reflector optical tube weighing 4.7kg to Files.
The counting unit circuit was modified so that the +5V power supply for the counting unit is supplied from the control unit.
5. Revised on May. 16,2024
Added a mechanical drawings of the telescope mount to the attachment files and added the link in the details body text.
6. Revised on Jun. 11, 2024
Added Chapter 7, Observation of globular clusters.
Added a short version software MCT-6_1.TXT to the attachment files.
7. Revised on Jun 13, 2024
Added a Fig. 16, a sketch of globular cluster M10.
8. Revised on Jul. 30, 2024
Added a description and the video link of the 200mm arm declination unit to Chapter 2.
9. Revised on Mar. 20, 2025
Added a photo of the 200mm long single fork mount configuration.
10. Revised on May. 06, 2025
Added Chapter 9, Next new project.
11. Revised on Jun. 21, 2025
Added a faster version application software MCT-6_4.TXT to the attachment files.
Added the error values to the Table 1 and Table 2 in the details.
