Key points
- Runs off 4 LXT 18V battery packs
- 1500W output (3kW peak)
- 360Wh capacity with 5Ah packs (432Wh with 6Ah packs )
- Fits in a large MACPAK case (otherwise known as Type 3 or Mbox3)
Planned upgrades
- Individual battery pack voltage/current monitoring
- Multiple USB(-C PD) outputs
Challenges
One of the biggest pain points while planning this project was finding an inverter that could run off the 72V provided by 4 18V battery packs connected in series, while still being powerful and compact enough. The only one I was able to find was this custom order from AliExpress, which came in a well-padded box and didn't break the bank. After ordering, I specified my exact requirements via chat with the seller, and it took less than 2 weeks to arrive.
Another challenge was designing a holder for the battery packs which were small enough to fit, and allowed for routing the 10AWG cables, while still allowing access to the contacts of the Makita 644808-8 terminal. Although they're not quite as reusable for other projects, all the mechanical dimensions could still be a good reference for other designs.
Thijs Koppen
ric866
Meta Unknown
deʃhipu
This is interesting, I am also pretty deep into Makita tools. Have you looked into what might have ro be done differently for the 40v battery platform?
