EC11-rotary-encoder-the-easy-way (on a single mcu input pin)
As rotary encoder without push button
what do we need
1x ATTINY45
2x 4K7
1x 10K
1x EC11
We have 2 options for the connection to the main MCU
with 2 outputs
1x pulse output when turning right
1x pulse output when turning left
The ATTINY45 provides 20 millisecond pulses on either the right turn output or the left turn output.
with 1 output
1x output
The ATTINY45 delivers either 10 millisecond pulses when turning clockwise or 20 millisecond pulses when turning counterclockwise on the same output.
As rotary encoder with push button
what do we need
1x ATTINY84
3x 4K7
1x 10K
1x EC11 with pushbutton
with 2 outputs
The ATTINY84 provides 20 millisecond pulses on either the right turn output or the left turn output.
Push button must be connected separately to main MCU
with 1 output
The ATTINY84 delivers
10 milliseconds pulses when turning clockwise
20 milliseconds pulses when turning counterclockwise
30 milliseconds pulse when push button is pressed
and this on the same digital output
Further specifications
power supply 3.3V or 5V
no extra capacitors or resistors
no libraries
works for slow and fast rotation
cheap about 3€
easy to build
Thanks to
https://www.elektormagazine.nl/labs/rotary-encoder-on-a-single-mcu-pin
for the 1 input idea
