PLA is preferred to ABS as you do not have to deal with nasty plastic smells. If this is used with a second filter, the plastic is never in touch with the coffee, nor with high temperature water.
The AeroTamper allows to brew espresso-style coffee right from the AeroPress coffee maker
Why do you need it? When I make coffee, most of grounds settle at bottom already. Does it really change flavour?
