Decided that I wanted a simple thermometer that would show the current temperature when I was in the house. So, in true maker fashion I decided that designing and building one would be the solution rather than going out and buying one.
Thus far I have created the project, created a github repository and decided on the components I would be using. All of which can be seen in the github repository. The next step is to begin with the hardware design and also document the journey.
TheBrokenEngineer
