This mod adds a latched footswitch mode to Tera Echo, a counterpart of holding your foot on the pedal. After stomping on the switch for a few seconds, the pedal goes into the "freeze" mode just like when holding it down all the time. It frees your foot up to do other things. Liked by synth afficionados.
I was asked to do a latch mod on a Boss pedal, a thing people already did in a different way: by using a latching footswitch, either added to the pedal itself or external. Both ways required drilling of the pedal's enclosure - which would mean it can't be restored to the original condition should it magically reach the Super-Duper-Unobtainium-Mojo-Vintage-Cult-Following-Yadda-Yadda status bringing up hundreds or thousands on Reverb. Not really a thing with mass-produced pedals, but still, thinking a few decades down the line. So, I decided the mod has to be 1) reversible, 2) invisible. At first I tried using a latching reed switch and a magnet, but this proved problematic as the reed switch needs different magnet orientations for the on and off action. Seeing this ain't gonna work, I went for electronic solution.
I did some research for latching switches and finally found a circuit based on two NAND gates forming a RS trigger, with RC circuits on the inputs, with different time constants for resetting and setting. I tried that with a 74HC00 (HC because I was dealing with 3.3V on VCC), got it to work, then went through a bunch of "what ifs"... like, can I build it with discrete transistors and diodes? This turned out utterly simple on a breadboard, and it worked after a bunch of tweaks, so I brought on my friend's Protel 99SE (call me old school! I was going to use it to learn the basics of Altium Designer, and it turned out the other way, with learning AD first and then Protel). I designed and etched a little PCB with surface mount parts, soldered it and it didn't want to work... Stray capacitances? EMI? Different part parameters? Not sure, but I modified the circuit some more to get it going and it works nicely now.
