As mentioned in decle's excellent entry on Dumping the TMS1100, some TMS1000 series chips obfuscated the ROM code by always asserting the high-bit in each instruction byte. In those chips the test mode only allows extraction of a partial ROM.
Interestingly, the patent to which decle referred also highlights that you can selectively execute the code on the TMS1000 series chips. Due to the specific details of the TMS1000 series instruction set, all bytes which really do have the high-bit set are branch or call instructions.
This means that if we execute the unknown instruction and we end up somewhere unexpected (i.e. the program counter is out of order) then the instruction really was a branch or call, and the high-bit really was set. If we end up at the very next instruction, it was (probably) not a jump.
I've updated decle's Arduino code to support this inference and automatically execute instructions to identify jumps as it dumps the ROM. I've also included a few more heuristics that help deobfuscate some of the more tricky corner cases; of which there are quite a few. The curious can check out the code for more details.
To accurately indicate any potentially incorrect instructions, the code puts a question mark (?) after any suspect bytes in the output. For the vast majority of instructions this will not apply and the heuristics mean that many of the suspect bytes will be correct, even if marked. For example, the code correctly dumps the complete known ROM of the Microcomputer Trainer despite being uncertain about 39 (of the 2048) instructions. If you don't want the question marks in the output they can be turned off.
#define WARN 0
However, if you are going to try and use the ROM in an emulator, or inspect a disassembled version line-by-line, having the question marks gives an indication of where to look if something goes awry.
You can use the revised code to dump the ROM from both the Science Fair Microcomputer Trainer, and the Gakken FX R-165 (if you're willing to take a soldering iron to your vintage computer). The code may work for other TMS1000 series chips, but is untested. I've also updated it to (hopefully) dump the ROM from the TMS1600 in the Busch Microtronic 2090. Michael recently discovered his Microtronic ROM is not obfuscated, but it did require a few small tweaks which my edits (should) handle.
To get started, I recommend watching decle's informative clocking video. This will help you ensure you can control the TMS chip. Taking control of the clock is an important first step. Here, decle uses a sped up Blink sketch.
As noted in the entry, I was able to get my Science Fair to dump the ROM at just 6V, but not all chips will work at such a low voltage. Using 6V does mean that, as long as you use the voltage divider on pin O7 to protect your Arduino, you can avoid the extra circuitry. This does require that you uninvert the high/low signals, but I provide a define statement that you can use to (un)swap the logic levels.
#define INVERT 0
If you're having trouble, or want a more detailed overview, then I've made a video showing how to check that all the signal levels are appropriate for the TMS chip. Note that I am using inverted logic here (I have set the above code to 1), as I am using the inverting amplifiers.
Finally, if you're looking to dump the TMS1600 you need to hold R8 high, instead of R6/R10, and you'll need to set the chapter size to four, as it has twice the ROM of the TMS1100.
#define CHAPTERS 4
As Michael discovered, the TMS1600 also has slightly different timing requirements; but this should already be handled by the LOAD_WAIT and LOAD_HIGH constants. This aspect of the code is untested though, so your milage may vary and you may need to make your own modifications.
The Science Fair Microcomputer Trainer is a great learning tool, but I’ve always felt the manual made it difficult to quickly (re)acquaint yourself with the instruction set. This seems particularly important with the the type of sporadic put-down/pick-up use that you might expect with any learning platform, especially one aimed at youngsters.
Unlike the Gakken FX R-165, on which it is based, the Science Fair version lacks a quick reference card (available at the end of the Japanese manual scan). Sure, the Microcomputer Trainer has the opcodes listed on the front panel, but it's not quite the same. So, please, allow me to present: The Missing Manual [Pages].
Some time ago I put together my own Command Quick Reference for the Science Fair. It’s not a direct translation of the Japanese, as I added a few extra hints to it (e.g. listing the run mode and games) and corrected a couple of minor errors from the original documentation; but it is clearly heavily inspired by it.
As you can see, I keep a printed copy with the unit for reference. If you print it at 85% and trim it with ~5mm margin (to the content) it neatly matches the dimension of the manual. I also find it useful as a cross reference back to the official instruction definitions in the Science Fair Microcomputer Trainer manual (as with the Japanese version, the page numbers refer to the callout boxes).
Some time later I discovered further details about the R-165's E3 CAL INPT instruction. Unfortunately the relevant pages were missing from the Japanese manual scan, but a fellow going by the name mikecat_mixc put up an interesting article on the R-165 which (with the use of Google Translate) allowed me to expand my documentation.
I subsequently added the included “Appendix B” to cover the use of the E3 CAL INPT instruction with the Science Fair, which, even though it is marked as NOT USED, is present and works just fine. Without access to the the Japanese manual this section of the document was much more speculative. You'll have to forgive my potentially poor explanations and examples!
In addition, although it was great to be able to use the "hidden" input feature, the transistor inverter approach seemed suboptimal. Using the "official" circuit means that you can’t use the keyboard and CAL INPT at the same time. However, I realised the limited number of patterns displayed on the seven segment display allowed us to abuse the “HEX. LED” as the input for a simple diode OR gate from which to supply the activation logic and power for the K inputs.
The diode approach actually ensures the display is on during CAL INPT. More importantly, it allows you to use both the keyboard and the CAL INPT command “simultaneously”. I present both options in the document. We have since discovered that the requirement of the display being “on” is just an artefact of the logic used to read the control keys, and the way the output PLA is used (in part) to scan the K inputs.
More recently I obtained the “missing” pages from the Japanese scan (and English translations), and my Appendix B and example program is very different from the originals. There are some possible minor misrepresentations, as this document predates our latest investigations, but I’m happy enough with it. Importantly, I think a diode logic approach, offering access to all four K inputs, is an improvement due to the enhanced functionality it offers.
This post details the approach that Sean Riddle and I took when dumping the code contained in the Science Fair Microcomputer Trainer (SFMT) back in 2015. This built on previous work by Kevin Horton (aka Kevtris). Although I'm writing this up, credit should go to Sean and Kevin. If this description inspires you to try ripping apart your favourite 1970s toys and microwave ovens to dump the firmware, I'd encourage you to check out Sean's website to see if he's done the hard work for you already.
The SFMT is based around the TMS1100. This is a derivative of the TMS1000 microcontroller released by Texas Instruments in 1974. The TMS1100 has a 4-bit CPU, 2K of ROM and 128 nibbles of RAM housed in a 28pin DIP. In the SFMT the firmware in the 2K ROM contains an emulator of a 4-bit virtual machine, and seven "games". It's quite impressive.
Dumping the firmware out of the ROM within a TMS1xxx is theoretically pretty simple. Fundamentally, there are two approaches.
Take your TMS1xxxx and grind the top off the package, exposing the die. Photograph the die. Remove the top metal layer from the die using acid, and photograph it again. Reverse engineer the ROM contents from the die images. This approach has the downside that it's pretty hard core and destructive, but it's comprehensive and is guaranteed to work.
Observe that US patent 4024386, which describes the TMS1000, details a test mode that can be used to extract the ROM contents from the pin O7. Reverse engineer this process which starts at column 27, line 20, and read the ROM contents electrically. Whilst this is non-destructive, it has a number of drawbacks. Firstly, the summary of the test mode in the patent is incomplete and somewhat confusing. Secondly, in addition to the ROM, the TMS1xxxx allows customisation of two other aspects of the processor, the instruction PLA and the output PLA. The test mode does not allow these customisations to be inspected. Finally, over time Texas Instruments made changes to the TMS1xxx design to cripple the test mode. Whilst it is possible to dump early chips, by the time the TMS1100 used on the SFMT was in production the method detailed in the patent would only dump 7 bits of each instruction, and it is believed that the even later chips disabled this technique altogether.
In the case of the SFMT, Sean had already followed the first method, but in the process of decapping the chip the die had been damaged. It was early in Sean's decapping career and this happens sometimes, but as a consequence he didn't have a complete picture of the ROM. I didn't fancy destroying my SFMT, so we investigated reconstructing the work done by Kevtris to make use of the second method.
After some fiddling, we came up with the following circuit that could be connected to an Arduino or similar that would allow us to exercise the TMS1100 test mode:
In this case I used an Arduino Micro to control the TMS1100, using six transistors as inverting level shifters up to the 9V PMOS logic used by Texas Instruments. These are used to drive the clock, INIT (reset) and four K input pins. ROM data is then read out of the O7 pin. A couple of resistors are needed on O7, one to pulldown the open collector output, and another to protect the Arduino from the 9V logic of the TMS1100. The only other wiring necessary is power and a connection from the R10 output (confusingly labelled R6 on the SFMT) to +9V. @Jason Jacques has subsequently found that it's possible to undervolt the TMS1100 and run it at 6V, bypassing the need for level shifting and allowing it to be connected directly to an Arduino. Obviously, both the TMS1100 and Arduino are technically out of spec at this point, so your mileage (and damage) may vary.
We then use this Arduino program to dump the ROM. This clocks addresses into the K input pins using the rather strange protocol required by the TMS1xxx, clocks the resulting data out of O7 and reports it over USB to your PC. I won't describe the details of the clocking mechanism here, the truth is in the function getData() for those that are interested.
As mentioned earlier, this will get us 7 of the 8 instruction bits (a copy protection FET on the die ensures bit 8 will always read high). In our case we were lucky and bit 8 was intact in Sean's original image. He was able to use this to provide the missing 8th bit. More generally, it may be possible to infer which of the 8th bits should be high because only TMS1xxx call and branch instructions assert this bit. Therefore, if it is initially assumed that all instructions are not branches or calls (bit 8 is low) it might be possible to assess the plausibility of each instruction actually being a branch or call in turn, based on the nature of the code at the implied target address. Happily, Sean's image meant this potentially error prone approach was not required.
In terms of understanding the TMS1100, that leaves identifying any customisation of the instruction and output PLAs. For the instruction PLA, disassembly has not indicated that there are any customisations to the TMS1100 instruction set. I suspect that typically there isn't much call to alter instruction behaviour, and this is the normal state of affairs. Disassembling the firmware also allows us to infer the contents of the output PLA. In the SFMT it's very similar to the standard 7 segment display setup described on page 2-21 of the TMS1000 Programmer’s Reference Manual. The minor differences to support keyboard scanning can be worked out from the reverse engineered code.
Now, armed with this powerful new knowledge, it's possible to write an emulator of the SFMT...
He implemented Nybl - a Science Fair emulator using the original ROM that runs on the Intellivision, and also has developed a method of dumping a TMS 1xxx ROM using the test mode. Great stuff!
With a good number of iterations, I managed to squeeze an "interactive" solver down to fit into just the 80 nibbles (40 bytes!) of the Microcomputer Trainer's memory.
The full listing follows.
The Listing
Memory address in column 1, 2, and 3; value to enter in column 4. Logical labels, relevant to program execution, are in column 5. The final two columns are a disassembly of the instruction, back to labels and opcodes. These correspond one-to-one with the final assembly language source (provided at the end of this entry).
; towers of hanoi for science fair microcomputer trainer
; (c) 2024 LambdaMikel & jtjacques
; assembled with https://arpruss.github.io/r165.html
; stack
; set 0x50 to a
; set 0x51 to c
; set 0x52 to b
; set 0x53 to 0
; initial state
; set z (0x6b) to n (0, 1, 2, 3)
; set y (0x6e) to 3 (pointer to m 0x53)
; start at hanoi (0x17), mode 2
; when pause (0x33, 0b0110011)
; reset, inspect y (0x6e)
; moves: inspect memory at 0x5[y] (from), 0x5[y+1] (to)
; resume at resume (0x00, or simply reset), mode 2
; when hlt (0x29, 0b0101001), program complete
0 0000000 00 B resume AIY
1 0000001 01 2 2
2 0000010 02 5 MA
3 0000011 03 B AIY
4 0000100 04 2 2
5 0000101 05 4 AM
6 0000110 06 B AIY
7 0000111 07 D D
8 0001000 08 5 MA
9 0001001 09 B AIY
10 0001010 0A 4 4
11 0001011 0B 4 AM
12 0001100 0C B AIY
13 0001101 0D B B
14 0001110 0E 5 MA
15 0001111 0F B AIY
16 0010000 10 6 6
17 0010001 11 4 AM
18 0010010 12 8 TIA
19 0010011 13 3 3
20 0010100 14 B lbl_6: AIY
21 0010101 15 1 1
22 0010110 16 4 AM
23 0010111 17 2 hanoi CH
24 0011000 18 D CIY
25 0011001 19 0 0
26 0011010 1A F JUMP
27 0011011 1B 3 lbl
28 0011100 1C 6 _0
29 0011101 1D F JUMP
30 0011110 1E 2 lbl
31 0011111 1F 5 _1
32 0100000 20 B lbl_3: AIY
33 0100001 21 C C
34 0100010 22 2 CH
35 0100011 23 B AIY
36 0100100 24 1 1
37 0100101 25 2 lbl_1: CH
38 0100110 26 5 MA
39 0100111 27 E CAL
40 0101000 28 6 SIFT
41 0101001 29 F halt lbl_2: JUMP
42 0101010 2A 2 lbl
43 0101011 2B 9 _2
44 0101100 2C C CIA
45 0101101 2D 0 0
46 0101110 2E F JUMP
47 0101111 2F 2 lbl
48 0110000 30 0 _3
49 0110001 31 B AIY
50 0110010 32 9 9
51 0110011 33 F pause lbl_4: JUMP
52 0110100 34 3 lbl
53 0110101 35 3 _4
54 0110110 36 B lbl_0: AIY
55 0110111 37 F F
56 0111000 38 2 CH
57 0111001 39 B AIY
58 0111010 3A D D
59 0111011 3B 5 MA
60 0111100 3C B AIY
61 0111101 3D 4 4
62 0111110 3E 4 AM
63 0111111 3F B AIY
64 1000000 40 E E
65 1000001 41 5 MA
66 1000010 42 B AIY
67 1000011 43 3 3
68 1000100 44 4 AM
69 1000101 45 B AIY
70 1000110 46 C C
71 1000111 47 5 MA
72 1001000 48 B AIY
73 1001001 49 5 5
74 1001010 4A 4 AM
75 1001011 4B 8 TIA
76 1001100 4C 1 1
77 1001101 4D F JUMP
78 1001110 4E 1 lbl
79 1001111 4F 4 _6
80 1010000 50 A source
81 1010001 51 C dest
82 1010010 52 B spare
83 1010011 53 0 return
Setup
The program does require you to specify the initial parameters for the first stack frame in the data area at addresses 0x50-0x53. This tells the computer the layout of your pegs, and sets the exit condition. For convenience I have included them at the end of the listing and you can simply carry on entry past the program area into the data area. However, for completeness they are as follows:
0x50: source (peg A),
0x51: destination (peg C)
0x52: spare (peg B)
0x53: 0 (return label)
While the names are arbitrary (you could call them pegs 1, 2, and 3, for example, if you prefer) the final return label (0) is required to allow the program to exit correctly.
You also need to configure two more parameters: the number of discs between 0 and 3 in 0x6B (the Z register) and the least significant nibble marking the end of the stack in 0x6E (the Y register), 3.
Important Note: documentation for the FX R-165 and Microcomputer Trainer indicate that the Z register is held in memory at location 0x6D. This appears to be an error. The Z register is located at 0x6B on real hardware (both the FX R-165 and Microcomputer Trainer) and on emulators using the ROM, but other simulations may implement the documented location of 0x6D.
Execution
Once you have entered the program and set your desired number of discs (0-3), you need to start the program from location 0x17, in run mode 2 (run with addresses). Press [1], [7], [addr-set] to set the program counter, then press [2] and [run] to start the program. Using run mode 2 means that we can monitor the program progress on the address bus (the binary LEDs) and read out our moves when the program pauses.
Result
When the program pauses, the address bus will read 0b0110011. When this happens, the program has calculated a move for us.
To read the move, first we must stop the program by pressing [reset]. This allow us to check the Y register, at 0x6E, by pressing [6], [E], [addr-set]. This will display the least significant nibble of the data area address where we will find our move. For example, if you see 4, we would inspect 0x54. e.g. [5], [4], [addr-set]. The computer will now display the from peg on the HEX LED. Press [incr] to see the to peg. For example, if we see [B], [C], we would move the top disc on peg B to peg C.
To find our next move, we simply resume the program in mode 2. For convenience, the resume address is at 0x00. This allows us to simply reset the machine: [reset], [2], [run]. The program will proceed to calculate the next move. If the binary LEDs indicate a pause (0b0110011) then repeat the inspection process, starting with the Y register. If the binary LEDs display 0b0101001 the program has completed.
Note that attempting to solve for numbers of discs 4 or greater will overflow the 16 locations made available as data memory (0x50-5F) and used for the stack. This will cause the program to "crash" or result in other unexpected behaviour.
How the Program Works
It is possible to put executable code in the memory area (0x50-5F) of the Science Fair Microcomputer Trainer, and therefore set return addresses at run time. However, each jump requires 3 nibbles (4-bit words) which is a lot of overhead; both in the stack frame and in code required to write these addresses to memory. Fortunately Michael gave me a great start with his initial work on the problem. Instead, I used his neat trick of constant return labels and return addresses calculated at assembly time.
The program went through multiple iterations, but the draft version fairly closely follows this example pseudo code.
TOH(N, A, B, C):
IF (N = 0): STOP
TOH(N-1, A, C, B)
A -> C
TOH(N-1, B, A, C)
Draft program
To make it easier to develop the program I use a very simple assembler. The opcode mnemonics are identical to those used in the Microcomputer Trainer documentation. While the assembler does not offer any macros, labels are supported. Using an assembler allows us to iterate our program faster and, importantly, ensures that all the jumps are correctly calculated in the final program.
The following code represents a basic, first attempt at implementing a (somewhat) interactive solver for Towers of Hanoi.
; assemble with https://arpruss.github.io/r165.html
; stack
; set 0x50 to a
; set 0x51 to c
; set 0x52 to b
; set 0x53 to 0
; initial state
; start at hanoi (0x??), mode 2
; when pause (0x??, 0b???????)
; resume at resume (0x??), mode 2
; when hlt (0x??, 0b???????), program complete
HANOI:
CH ; get b/z
CIY 0 ; z <> 0
JUMP CALL1 ; then start
JUMP RETURN ; else return
CALL1:
AIY F ; disk - 1 (z)
CH ; restore a/y
; swap 1 ; prepare stack
; s =+0, d =+1, x =+2, r =+3
; s'=+4, d'=+5, x'=+6, r'=+7
; y = 3
; s' <- s
; d' <- x
; x' <- d
AIY 3 ; move to x'
; AIY D ; s
; MA
; AIY 4 ; s'
; AM
; AIY E ; x
; MA
; AIY 3 ; d'
; AM
; AIY C ; d
; MA
; AIY 5 ; x'
; AM
TIA 1 ; lbl 1
AIY 1 ; advance to r'
AM ; set lbl
JUMP HANOI ; recurse
RET1:
; AIY C ; unwind stack
; ; CH ; get b/z
; ; AIY 1 ; restore disk number (z)
; ; CH ; restore a/y
; AIY D ; move stack to s
AIY 9 ; unwind stack and move to s
PAUSE:
JUMP PAUSE ; pause
RESUME:
AIY 3 ; move stack to r
CALL2:
; CH ; get b/z
; AIY F ; disk - 1 (z)
; CH ; get a/y
; swap 2 ; prepare stack
; y = 3
; s' <- x
; d' <- d
; x' <- s
AIY 3 ; move to x'
; AIY F ; x
; MA
; AIY 2 ; s'
; AM
; AIY D ; d
; MA
; AIY 4 ; d'
; AM
; AIY B ; s
; MA
; AIY 6 ; x'
; AM
TIA 2 ; lbl 2
AM ; set lbl
RET2:
CH ; get b/z
;JUMP RETURN ; fallthrough
RETURN:
CH ; restore a/y
MA ; get r
CIA 0 ; r <> 0 ?
JUMP TEST ; then goto test
HLT: ; else
JUMP HLT ; hlt
TEST:
CIA 1 ; r <> 1 ?
JUMP RET2 ; then ret2
JUMP RET1 ; else ret1
The program is fairly intelligible and its structure mimics that of the pseudo code. First we check if the number of discs is > 0, if not we exit the function by returning. Otherwise, we begin our first function call. Here we decrement the disc number (disk - 1), then begin to arrange our stack (or we would, but I comment this out for brevity and replaced it with a stub during testing).
Note that the Microcomputer Trainer does not have a subtraction instruction. Subtraction is achieved by causing the sum to overflow and wrap around. To discover the number to add, simply subtract the desired value from 0x10. For example, to subtract 0x1 we instead need to add 0xF as 0x10-0x1=0xF.
Finally, we complete the stack configuration for our first recursive call. We load the constant 1 into the accumulator, advance the stack pointer (the Y register) to the correct location, and store the return label in memory.
The program then does its first recursion, by jumping back to HANOI. When that call is done, the function will return (more on that later) and we will be put back at RET1. Here we pop the stack (or unwind, as I note in the comments), correct the disk number (the decrement should only affect the call we just made) and move to the Y register to point to the source peg in the current stack frame.
Here we see our first optimisations. Notably, there is no need to actually restore the disk number. No one is looking at it right now, and we are going to need to decrement it again in a moment for the second recursive call. So we comment that code out, saving four nibbles. This would leave two adjacent AIY instructions to advance the Y register. We can simplify this by summing these together and doing a single add to save a further two nibbles. The sum of AIY 0xD and AIY 0xC is 0x19. As this is a 4-bit machine, we simply add the lower nibble, and do AIY 0x9.
We then pause the program with a jump to the PAUSE label. This allow the user to exit out of the program and retrieve the calculated move as indicated on the stack at the position indicated by the Y register.
We then expect the user to resume the program at RESUME. We move the stack pointer (the Y register) back to the end of the stack and prepare our second recursive call. We've already commented out the redundant decrement of the disk number (as we didn't restore it), saving another four nibbles. Simply avoiding restoring and re-decrementing the disk number has saved us 10 nibbles, with no impact on execution an only a minor impact on readability.
Next, we managed the stack. For brevity we use a stub to skip over doing the actual swaps while we develop the code. Like with the first call, we set our return label, but this time to 2 to indicate that this is the second recursive call. We load the constant into the accumulator, advance the stack pointer, and store the return label in memory.
When this call completes, we will be retuned to the RET2 label. Here we again pop the stack, restore the disk number (this time we need to!) and jump to RETURN. Or we would, but why waste memory jumping to the very next instruction? Instead we simply fall through. An instant and totally free saving of three nibbles.
Now we get to the RETURN block. Michael gives a great explanation of this concept, which he calls the "jump block", in his video where he demonstrates recursion on the Busch Microtronic 2090. Essentially, we retrieve the label at the stack pointer and do a series of tests. The Microcomputer Trainer tests for inequality, which makes this a bit more confusing, but in summary: if the label is <> 0, we will TEST the label further, otherwise we halt (using a loop to HALT). In the TEST section, if the label is <> 1 (i.e. 2), we jump to the label RET2, otherwise it must be 1 so we jump to RET1.
Shrinking the Program
If we uncomment the swaps (and remove the stub code) and assemble the program we find it is 94 nibbles. While we could just about fit the program into the combined memory and data space of 96 nibbles (80 in the program area at 0x00-4F, plus the first 14 from the adjacent data area at 0x50-5D), that would leave just two nibbles (0x5E-5F) for our stack; not even enough for a single frame. First we double check our code for any easy wins.
We notice two adjacent AIY instructions in the RESUME and CALL2 areas that have surfaced when we uncommented the proper stack management code. We add the values of 0x3 and 0xF to get 0x12, and simply add 0x2 as is sufficient in our 4-bit architecture. This saves us two nibbles. Down to 92.
Our optimisations so far have not materially impacted intelligibility, but to shrink the program further we need to tweak the code somewhat.
Next we notice some duplicate code. Both CALL1 and CALL2 end with the sequence, AIY 1, AM, JUMP HANOI to set the return location on the stack and actually execute the recursive call. We squeeze in a no-cost label of SETR above this code in CALL2 and remove the corresponding code from CALL1. Instead we jump to our new label. This gives us a net saving of three nibbles. Down to 89.
The code is still fairly understandable, but now we will flip that on its head. Literally.
Next, we rearrange the program to maximise the amount of fall through. Each jump takes three nibbles of memory. By rearranging the program we can loose two more jumps (in addition to the one we saved earlier), another saving of 6 nibbles. Down to 83. We also take the opportunity to move the frequently used RESUME block to 0x00, minimising the number of times the user has to explicitly set the program counter.
To squeeze out the final nibbles, we get a little more tricksy. The RETURN block does a bit of an odd pattern of jumps due to the inequality operation. It would be nice to test if the label is 0 and, if it is, halt right away. To do this we can do a no-cost substitution of the two nibble CIA 0 operation, replacing it with a two nibble call to CAL SIFT. This built in subroutine shifts the value in the accumulator to the right and (oddly) sets the jump flag to true if the lowest bit was zero. This allows us to remove the JUMP TEST instruction and immediately halt when we see an even number, like zero. If we have an odd number, the jump will be skipped and we can begin the next TEST. Removing the jump makes a three nibble saving. Down to 80.
Unfortunately, our label of 2 would also now trigger the HALT loop, so we make sure to make a no-cost change and replace the TIA 2 instruction to TIA 3 (or 0b11, as I like to think of it now). Equally, we need to consider the effect of that shift on our comparison in the TEST block, where we change our CIA 1 to CIA 0, to account for the fact that 1 right shifted is 0 (and 3 right shifted would be 1).
The final listing looks like so:
; stack
; set 0x50 to a
; set 0x51 to c
; set 0x52 to b
; set 0x53 to 0
; initial state
RESUME:
;AIY 3 ; move stack to r
CALL2:
; CH ; get b/z
; CH ; get a/y
; y = 0
; s' <- x
; d' <- d
; x' <- s
;AIY 6 ; move to x'
AIY 2 ; x
MA
AIY 2 ; s'
AM
AIY D ; d
MA
AIY 4 ; d'
AM
AIY B ; s
MA
AIY 6 ; x'
AM
TIA 3 ; lbl 0b11
SETR:
AM ; set lbl
;JUMP HANOI ; recurse ; fallthrough
HANOI:
CH ; get b/z
CIY 0 ; z <> 0
RET2:
CH ; get b/z
RETURN:
CH ; restore a/y
MA ; get r
CAL SIFT ; (r & 1) <> 1 (i.e. is r even) ?
HLT: ; then
JUMP HLT ; hlt
TEST: ; else
CIA 0 ; (r >> 1) <> (0b1 >> 1) ?
;JUMP RET1 ; else ret1 ; fallthrough
RET1:
; ; CH ; get b/z
PAUSE:
JUMP PAUSE ; pause
CALL1:
CH ; restore a/y
; y = 3
; s' <- s
; d' <- x
; x' <- d
;AIY 3 ; move to x'
AIY D ; s
MA
AIY 4 ; s'
AM
AIY E ; x
MA
AIY 3 ; d'
AM
AIY C ; d
MA
AIY 5 ; x'
AM
TIA 1 ; lbl 0b1
; AIY 1 ; advance to r'
; AM ; set lbl
; JUMP HANOI ; recurse
JUMP SETR
If we run this through the assembler (or assemble it by hand), we get the very same sequence of instructions shown at the beginning of this entry.
Conclusion
In truth, and as Michael could attest, there were a fair few more iterations of this. Previous versions had to dip into the data area to fit. Throughout the process, many subtle sequencing decisions were made at indeterminate points to minimise the use of CH and the swaps of the Y and Z registers. Equally, I admit I did some last minute post-hoc rearranging of code, such as the order of the TIA and AIY instructions around the SETR label to maximise the opportunity for code reuse. Choosing which of the blocks to keep and which to discard may sometimes also require some trial and error in maximising total overall code savings.
Equally, the more abstract program design goals evolved over time. Very early iterations attempted some actual program driven I/O, as seen in the Microtronic version, rather than relying on the address LEDs to indicate state. Unfortunately, this was quickly dismissed as impractical. I did choose to retain the programatic pauses, however, so that there is no need to single-step the program and some semblance of an interactive experience remains.
Overall while many design trade-offs were made, I think it is fair to say we did achieve the goal of squeezing a Towers of Hanoi solver into just 80 nibbles (40 bytes) of memory. I hope you've enjoyed this deep dive into the code as much as I have. Despite its limitations, the Microcomputer Trainer clearly is a "real" computer. And for me, at least, it is yet to truly disappoint!
Not entirely unexpected, and not entirely serious either, but nonetheless - impressive! While it mostly failed to translate its generated assembly code into machine language (It's not a good assembler), the delivered assembly code actually worked in the end.
Yes, it required significant hand-holding on my behalf - however, unlike for common assembly language dialects such as Z80, 6502, 68k, x86, etc., it certainly hasn't been trained on large amounts of Science Fair trainer code.
Now, the real question is of course - when can we expect Science Fair Assembler support in Copilot, Microsoft? :D
Here you go:
Can you help me write an assembly program?
ChatGPT
Of course! I'd be happy to help you write an assembly program. Could you please provide more details about what you want the program to do? Additionally, let me know which assembly language you're working with (e.g., x86, ARM, MIPS) so I can tailor the code accordingly.
It's the Science Fair microcomputer trainer. Heard of that?
ChatGPT
Yes, I'm familiar with the Science Fair microcomputer trainer. It's a simple microcomputer trainer kit often used for learning assembly language programming. What specific task or program would you like to create for it?
Can you create a counter that uses the hex display.
ChatGPT
Sure! Here's a simple assembly program for the Science Fair microcomputer trainer that implements a counter and displays its value on the hex display. This assumes an 8-bit microcontroller and a 7-segment hex display.
ORG 0x00 ; Start address
Main: MOV R0, #0 ; Initialize counter
MOV R1, #0 ; Initialize display index
Loop: MOV P1, R0 ; Output counter value to hex display
CALL Delay ; Delay for some time
INC R0 ; Increment counter
CMP R1, #15 ; Check if display index reached 15 (hex F)
JZ ResetIndex ; If so, reset display index
INC R1 ; Increment display index
JMP Loop ; Repeat loop
ResetIndex:
MOV R1, #0 ; Reset display index
Delay: ; Delay subroutine
MOV R2, #255 ; Initialize delay counter
DelayLoop:
DJNZ R2, DelayLoop ; Decrement delay counter and loop until zero
RET
This program initializes a counter (R0) and a display index (R1) to zero. It then enters a loop where it outputs the value of the counter to the hex display, increments the counter, and checks if the display index has reached 15 (hex F). If it has, it resets the display index. After each iteration, it calls a delay subroutine to introduce a delay before updating the display again.
Please note that the actual addresses and instructions might vary depending on the specific microcomputer trainer and assembly language you're using. Make sure to adapt the code accordingly.
That's the wrong instruction set.
ChatGPT
Apologies for the confusion. Let's try again using an assembly language suitable for the Science Fair microcomputer trainer. Below is an example program using a hypothetical assembly language compatible with the Science Fair microcomputer trainer:
ResetIndex:
DelayLoop:
RET
This assembly program initializes a counter in the X register and continuously increments it. It updates the hex display with the current value of the counter. If the counter reaches 15 (hex F), it resets the counter to 0 and updates the hex display accordingly. It includes a delay subroutine to introduce a delay between each update of the display.
Please note that this code assumes a specific assembly language and memory organization that may not exactly match the Science Fair microcomputer trainer. You may need to adjust the code according to the actual instruction set and memory layout of your microcomputer trainer.
Let me give you the instruction set:
0 | KA | 0 | A <- keyboard (use with JUMP, Flag = 0 when key, else 1)
1 | AO | 1 | Hex disp <- A
2 | CH | 2 | A <-> B exchange, and Y <-> Z as well
3 | CY | 3 | A <-> Y exchange,
4 | AM | 4 | M(Y) <- A
5 | MA | 5 | A <- M(Y)
6 | M+ | 6 | A <- A + M(Y)
7 | M- | 7 | A <- A - M(Y)
8 | TIA n | 8 n | A <- n
9 | AIA n | 9 n | A <- A + n
A | TIY n | A n | Y <- n
B | AIY n | B n | Y <- Y + n
C | CIA n | C n | A = n -> Flag ( then 0, else 1)
D | CIY n | D n | Y = n -> Flag ( then 0, else 1)
E | CAL #routine | E n | Call subroutine, argument in A if needed
F | JUMP low high | F low high | Goto low + 16*high
RSTO: 0 - turn off HEX display
SETR: 1 - turn on LEDs (from Y: 0..6)
RSTR: 2 - turn off LEDs
----: 3 - not used
CMPL: 4 - complement A (bit flip)
CHNG: 5 - exchange A <-> A', B <-> B', Y <-> Y', Z <-> Z'
SIFT: 6 - shift right A
ENDS: 7 - make end sound
ERRS: 8 - make error sound
SHTS: 9 - make short sound
LONS: A - make long sound
SUND: B - make organ sound (from A)
TIMR: C - timer (from A)
DSPR: D - show mem at addresses 50 - 51 (LEDs) and 52 (HEX)
DEM-: E - Dec. sub of 2 digits -> DEC; A - M(Y) -> M(Y) in DEC; Y <- Y - 1
DEM+: F - Dec. add of 2 digits -> DEC; A + M(Y) -> M(Y) in DEC; Y <- Y - 1
ChatGPT
Thank you for providing the instruction set. Based on that, here's a counter program for the Science Fair microcomputer trainer:
Main: TIA #00 ; Load accumulator with initial value (00)
AO ; Output accumulator to hex display
Loop: M+ ; Add 1 to the value in memory location pointed by Y register
CIY #0F ; Check if Y register reached 15 (hex F)
JUMP Reset ; If so, jump to Reset
JUMP Loop ; Repeat loop
Reset: TIY #00 ; Reset Y register to 0
END ; End of program
In this program:
The accumulator (A) holds the current value of the counter.
The memory location pointed by the Y register is used to store the counter value.
The program initializes the counter to 0, then enters a loop where it increments the counter value in memory and outputs it to the hex display.
If the counter reaches 15 (hex F), it resets the counter to 0 and continues the loop.
The program uses the CIY instruction to compare the value in the Y register with 15, indicating the end of counting.
Please note that this code assumes that the hex display is automatically updated whenever the accumulator is changed. If this is not the case, additional instructions may be needed to update the display after modifying the counter value. Additionally, ensure that memory locations used for counter storage and looping are available and properly managed.
Can you please count in A only.
ChatGPT
Certainly! Here's the modified program to count using only the accumulator (A) and output the value to the hex display:
Loop: AIA #01 ; Increment accumulator by 1
CIA #0F ; Check if accumulator reached 15 (hex F)
Reset: TIA #00 ; Reset accumulator to 0
This program operates similarly to the previous one, but it counts using only the accumulator (A). It increments the accumulator by 1 in each iteration and outputs its value to the hex display. When the accumulator reaches 15 (hex F), it resets the accumulator to 0 and continues counting.
Please ensure that the instructions are compatible with the instruction set of the Science Fair microcomputer trainer, and adjust as necessary based on any specific requirements or limitations of the trainer.
OK, getting better. However, make sure that only 4 bit operands are used.
ChatGPT
Understood. Let's modify the program to ensure that only 4-bit operands are used:
In this modified program:
We've ensured that the initial value, increment, and reset values for the accumulator are represented using only 4 bits.
The initial value is 0000, the increment value is 0001, and the reset value is 1111.
These values ensure that only 4-bit operands are used throughout the program, meeting the requirement.
Please verify the instructions and ensure compatibility with the Science Fair microcomputer trainer's instruction set. Let me know if you need further adjustments!
Instead of #0x, use just x
ChatGPT
Got it. Here's the modified program using the "x" notation instead of "#0x":
Main: TIA 0x00 ; Load accumulator with initial value (0000 in 4-bit representation)
Loop: AIA 0x01 ; Increment accumulator by 1
CIA 0x0F ; Check if accumulator reached 15 (1111 in 4-bit representation)
Reset: TIA 0x00 ; Reset accumulator to 0 (0000 in 4-bit representation)
In this version, I've replaced the "#0x" notation with just "x" for specifying immediate values. This notation is common in some assembly languages, so it should be suitable for the Science Fair microcomputer trainer. If there are any other adjustments you'd like, feel free to let me know!
Sorry, you misunderstood. I mean, instead of #01, use 1, instead of #0F, use F, etc.
ChatGPT
Thank you for clarifying. Here's the program modified as per your request, using hexadecimal literals without the "#" symbol:
Main: TIA 00 ; Load accumulator with initial value (0000 in 4-bit representation)
Loop: AIA 01 ; Increment accumulator by 1
CIA 0F ; Check if accumulator reached 15 (1111 in 4-bit representation)
Reset: TIA 00 ; Reset accumulator to 0 (0000 in 4-bit representation)
In this version, I've replaced the immediate values "#00", "#01", and "#0F" with "00", "01", and "0F", respectively, using hexadecimal notation without the "#" symbol. This should meet your requirement of using only hexadecimal literals without any prefixes. If you need further modifications or assistance, feel free to ask!
Now replace 01 with 1, 0F with F, 00 with 0, etc.
ChatGPT
Got it. Here's the program with the immediate values represented using only hexadecimal digits without any prefixes:
Main: TIA 0 ; Load accumulator with initial value (0000 in 4-bit representation)
Loop: AIA 1 ; Increment accumulator by 1
CIA F ; Check if accumulator reached 15 (1111 in 4-bit representation)
Reset: TIA 0 ; Reset accumulator to 0 (0000 in 4-bit representation)
In this version, I've replaced the immediate values "0", "1", and "F" without any prefixes. These values are represented using only hexadecimal digits, meeting your requirement. If you need further assistance, feel free to ask!
Please note that the FLAG register, and hence a jump, is only executed when the CIA operand is UNEQUAL to the A register.
ChatGPT
Thank you for the clarification. I've adjusted the program accordingly to ensure that the CIA instruction only triggers a jump when the accumulator (A) is not equal to the operand:
JUMP_IF_NOT_EQUAL Loop ; If not equal, repeat loop
JUMP Reset ; If equal, jump to Reset
In this version, the JUMP_IF_NOT_EQUAL instruction (not explicitly stated in the instruction set you provided) is used to jump to the Loop label only when the accumulator (A) is not equal to the value in the CIA operand. If the accumulator is equal to the operand (indicating that the counter has reached 15), the program jumps to the Reset label. If you have any further questions or need additional adjustments, feel free to ask!
Note that JUMP_IF_NOT_EQUAL is the same as JUMP. So the semantics of JUMP is exactly that o JUMP_IF_NOT_EQUAL. So you can only use JUMP.
ChatGPT
Understood. In that case, we'll use the JUMP instruction with the understanding that it will jump when the accumulator (A) is not equal to the value in the CIA operand. Here's the adjusted program:
JUMP Loop ; If not equal, repeat loop
In this version, the JUMP instruction is used to either repeat the loop or jump to the Reset label based on the result of the comparison between the accumulator (A) and the value in the CIA operand. If the accumulator is not equal to the operand, the program repeats the loop. Otherwise, it jumps to the Reset label. If you have any further questions or need additional adjustments, feel free to ask!
I don't think you should call the label "Reset". Rather, it should be called "End".
ChatGPT
Understood. Let's rename the label to "End" to better reflect its purpose. Here's the updated program:
JUMP End ; If equal, jump to End
End: TIA 0 ; Reset accumulator to 0 (0000 in 4-bit representation)
In this version, I've renamed the label to "End" to indicate that it's the end of the program where the accumulator is reset to zero before continuing the loop. If you have any further questions or need additional adjustments, feel free to ask!
Also, why do we need JUMP End at all? Can't we just omit it?
ChatGPT
You're absolutely correct. Since the program loops back to the "Loop" label after resetting the accumulator at the "End" label, we don't actually need the JUMP End instruction. It can be safely omitted, and the program will still function as intended. Here's the revised version without the unnecessary jump:
Thank you for pointing that out. If you have any further questions or need additional assistance, feel free to ask!
Now, instead of starting over from End: on, why don't we just wait for keypad input first and then reset the counter to zero and start over after a button has been pushed.
ChatGPT
Certainly! We can modify the program to wait for keypad input before resetting the counter to zero and starting over. Here's the updated program:
WaitKey:
KA ; Wait for keypad input
JUMP_IF_NOT_EQUAL WaitKey ; Wait until a key is pressed
JUMP Reset ; If equal, reset counter and wait for key again
In this version:
We added a new label "WaitKey" to wait for keypad input using the "KA" instruction.
The program will wait in a loop until a key is pressed.
Once a key is pressed, it jumps to the "Reset" label, resets the counter to zero, and starts over the counting loop.
This allows the program to wait for user input before resetting the counter, as you requested.
Feel free to ask if you have any further questions or need additional assistance!
This is incorrect.WaitKey should only be executed at the end of the loop.
ChatGPT
Apologies for the misunderstanding. Let's adjust the program so that the "WaitKey" routine is executed only at the end of the loop. Here's the corrected version:
WaitKey:
In this corrected version, the "WaitKey" routine is placed at the end of the loop. This ensures that the program waits for keypad input only after the counting loop has completed. If you have any further questions or need additional assistance, feel free to ask!
Very good. But you are using JUMP_IF_NOT_EQUAL again.. please correct. Note that KA set F = 1 if no key has been pressed. Hence, the JUMP is only executed if no key has been pressed. When a key has been pressed, F=0 is set, and the following JUMP is skipped, as desired.
ChatGPT
Thank you for the clarification. Let's adjust the program accordingly. We'll use the "KA" instruction to check if a key has been pressed, and if not, we'll jump to the "Reset" label. Here's the corrected version:
WaitKey:
KA ; Check if a key has been pressed
JUMP Loop ; If no key has been pressed, repeat loop
In this version, we use the "KA" instruction to check if a key has been pressed. If no key has been pressed (indicating that F=1), the program jumps to the "Reset" label to reset the accumulator and start over. If a key has been pressed (indicating that F=0), the program continues with the counting loop.
Thank you for your patience, and please let me know if you have any further questions!
You are supposed to wait until a key has been pressed. Double check your JUMP Loop instruction in the WaitKey: part.
ChatGPT
You're correct, my apologies for the oversight. We need to ensure that the program waits until a key has been pressed before proceeding. Here's the corrected version:
WaitKey:
JUMP_IF_NOT_EQUAL WaitKey ; If no key has been pressed, wait again
In this corrected version, the program will wait at the "WaitKey" label until a key has been pressed (F=0), at which point it will proceed to the "Reset" label to reset the accumulator and start over. If you have any further questions or need additional assistance, feel free to ask!
There is no JUMP_IF_NOT_EQUAL !
ChatGPT
You're correct, and I appreciate your patience. Here's the corrected version without using the JUMP_IF_NOT_EQUAL instruction:
JUMP_IF_EQUAL WaitKey ; If equal, wait for key
WaitKey:
In this corrected version:
After each increment of the accumulator, the program checks if the accumulator has reached 15. If it has, it jumps to the "WaitKey" label to wait for a key press.
If the accumulator is less than 15, the program continues with the counting loop.
At the "WaitKey" label, the program waits until a key has been pressed. Once a key has been pressed, it resets the accumulator and starts the counting loop again.
Thank you for your understanding, and please let me know if you have any further questions!
Please use JUMP only.
ChatGPT
Understood, let's simplify the program to use only the JUMP instruction. Here's the updated version:
WaitKey:
CIA F ; Check if a key has been pressed
JUMP_IF_EQUAL WaitKey ; If no key has been pressed, wait again
In this version:
Please only use JUMP - there is no JUMP_IF_EQUAL and no JUMP_IF_NOT_EQUAL. Note that, if F = 1 , then the JUMP is executed. If F = 0, then the JUMP is skipped. F = 1 is true if, for CIA n, A <> n, else F = 0 for A = n. Moreover, F = 1 for KA if no key has been pushed, else F = 0 if a key has been pushed.
ChatGPT
Thank you for the clarification. Let's simplify the program to only use the JUMP instruction. Here's the revised version:
WaitKey:
In this version:
After each increment of the accumulator, the program checks if the accumulator has reached 15. If it hasn't (A ≠ 15), the program continues with the counting loop.
At the "WaitKey" label, the program waits until a key has been pressed (F = 0). Once a key has been pressed, it resets the accumulator and starts the counting loop again.
The JUMP_IF_EQUAL instruction is used at the "WaitKey" label to check if a key has been pressed. If a key has not been pressed (F = 1), the program jumps back to "WaitKey" to continue waiting.
I appreciate your patience, and please let me know if you have any further questions!
Replace JUMP_IF_EQUAL WaitKey with JUMP WaitKey.
ChatGPT
Thank you for the clarification. Here's the updated version with JUMP WaitKey instead of JUMP_IF_EQUAL WaitKey:
WaitKey:
JUMP Loop ; If no key has been pressed, wait again
In this version:
The JUMP WaitKey instruction is used to loop back to "WaitKey" if no key has been pressed (F = 1).
I said "JUMP WaitKey", but you used "JUMP Loop" !
ChatGPT
Apologies for the oversight. Let's correct that. Here's the revised version with "JUMP WaitKey" as requested:
WaitKey:
JUMP WaitKey ; If no key has been pressed, wait again
Now, the program will jump back to the "WaitKey" label if no key has been pressed, as specified. Thank you for your patience, and please let me know if you have any further questions!
Excellent, you got it! But, can you optimize the Reset: part?
ChatGPT
Certainly! We can optimize the "Reset" part by moving the TIA 0 instruction outside the Reset label, thereby reducing duplication. Here's the optimized version:
WaitKey:
Reset:
In this optimized version:
The TIA 0 instruction, which resets the accumulator to 0 (0000 in 4-bit representation), is moved outside the Reset label.
This eliminates the duplication of the TIA 0 instruction, making the code more concise and efficient.
Thank you for suggesting the optimization! If you have any further questions or need additional assistance, feel free to ask!
Why do we need AO in Reset: ?
ChatGPT
You're correct; the AO instruction in the Reset label is unnecessary since we don't need to output the accumulator value to the hex display after resetting it to zero. Here's the optimized version without the unnecessary AO instruction:
WaitKey:
Reset:
In this optimized version, I've removed the AO instruction from the Reset label since it's not necessary to output the accumulator value after resetting it to zero. Thank you for catching that oversight! If you have any further questions or need additional assistance, feel free to ask!
I was thinking that we JUMP Main in Reset: ...
ChatGPT
Thank you for the clarification. If you intend to jump back to the beginning of the program after resetting the accumulator to zero, we can indeed use JUMP Main instead of JUMP Loop in the Reset label. Here's the updated version:
WaitKey:
Reset:
JUMP Main ; Jump back to the beginning
Now, in the Reset label, the program will jump back to the Main label, effectively restarting the program after resetting the accumulator to zero. Thank you for the clarification, and please let me know if you have any further questions!
Excellent. Now please translate this into machine code. Now that the addresses are from 00 to 4F (hexadecimal). Eliminate all labels and ensure that JUMP target addresses are correct.
ChatGPT
Sure, let's translate the assembly code into machine code. We'll eliminate the labels and ensure that the target addresses for jumps are correct. Here's the machine code:
ORG 00 ; Start address
; Main:
TIA 0
AO
AIA 1
AO
CIA F
JUMP 03 ; If not equal, repeat loop
; WaitKey:
KA
JUMP 07 ; If no key has been pressed, wait again
; Reset:
JUMP 00 ; Jump back to the beginning
Here, each instruction is represented by its corresponding machine code:
TIA 0: 0x00
AO: 0x01
AIA 1: 0x11
CIA F: 0x2F
JUMP: The address where the jump is targeted. For example, JUMP 03 corresponds to 0x03, JUMP 07 corresponds to 0x07, and JUMP 00 corresponds to 0x00.
Ensure to adjust the jump target addresses according to the memory organization of the microcomputer trainer. If you have any further questions or need additional assistance, feel free to ask!
Gret, but please eliminate all labels and mnemonics. Only use addresses and op-codes, i.e., 00 8 01 1 ... etc.
ChatGPT
Understood, let's eliminate all labels and mnemonics and use only addresses and op-codes. Here's the translated code:
00 8
01 1
02 9
03 1
04 2
05 F
06 F
07 F
08 0
09 F
0A 7
0B 0
0C 0
In this representation:
Each line represents an instruction.
The first column represents the memory address.
The second column represents the op-code.
Please double check. The first 4 instructions are correct, the rest looks wrong.
After 10 or so more turns, I gave up and stopped the dialogue. It did not succeed in creating the machine language program. However, it was able to crank out the assembler version - and I am impressed!
Even though it claimed to know the Science Fair machine, this was clearly not the case, as its first assembler programming attempts testified. After I provided the instruction set, it was able to pick this up and use it and do a halfway decent job - I have to say that I did *not* learn Science Fair trainer assembly at that pace! It is clearly demonstrating some basic "understanding" of fundamental assembly programming concepts.
Now, are these shimmers of understanding, or is it just stochastic parroting? I think it is very unlikely that GPT was trained on Science Fair assembly language. But, it had seen enough assembly code to form a more general and somewhat more generalizable underlying representation ("mode") that did allow it to use it successfully.
It is also clear that the "Eliza effect" is at work here - I was guiding it through the process and provided my knowledge as well. So in a sense, this assembler program is to a great extent also my own brain-child. I gave ChatGPT "scocratic questions" and guided it through its errors and omissions, steering it to success.
Jason joined the team! He reached out to me after my first YouTube video so that I could set the record straight and correct some inaccuracies, in particular, the release year of the Science Fair trainer. Jason pointed me to the original Radio Shack catalog from 1985 when it was first released. I could then correct the trainer's debut year from 1976 to 1985.
I then also took the opportunity to "nerd-snipe" him in a second email, regarding my attempted (but failed) recursive Towers of Hanoi implementation on the Science Fair - with his extensive Science Fair knowledge and programming experience, would he be able to fit it in?
And indeed, he was! I hence invited him to join the team - he gave me permission to include his recursive version of the Towers of Hanoi on the project. But nobody explains a program better than the author - so I am hoping that he will use his new team member privileges to upload his program here and maybe write a sentence or two explaining it.
So, if you like, take it from here, @Jason Jacques - either by adding it directly to the details section, or as a new log entry, as you like!
FUNCTION MoveTower(disk, source, dest, spare):
IF disk == 0, THEN:
move disk from source to dest
ELSE:
MoveTower(disk - 1, source, spare, dest)
MoveTower(disk - 1, spare, dest, source)
END IF
Previously, I succeeded doing this for the Microtronic - the Microtronic doesn't offer a native stack, nor programmatic access to the RAM! RAM is only for program memory (-> Harvard Architecture), and writable memory is register memory only. So implementing a stack for recursion is not so straight forward, but it is possible by shifting its set of 16 "extra registers" up and down to emulate push and pop operations to a stack (altogether, the Microtronic has 2x 16 4bit registers):
Also, there are no computed or "indirect" jumps - it is not possible to put a return address in a register (or memory) location and simply jump "indirectly" to the address stored there.
Hence, I used numeric jump labels and something I called a "jump block" - to do a computed jump (i.e., a return from a recursive call or subroutine to a variable address), I am comparing a register that I set up to act as "return" register to these numeric jump labels and execute conditional jumps accordingly. Putting the 2 techniques together I was then able to implement both a value and a return stack and hence could execute the recursive version of the towers of Hanoi for up to n=4 disks; you can find the Microtronic program here to get the idea: https://github.com/lambdamikel/picoram2090/blob/main/software/1.1/HANOI.MIC
Would the same techniques work for the Science Fair? In particular, since the Science Fair offers indexed memory access - load & store to the data region from 0x50 - 0x5F via the Y "index" register is possible, using the op-codes `AM (4)` and `MA (5)`, I though at least the stack implementation should be much more straight forward:
And indeed, using the Y-register as index into the data region, and being able to do "stack arithmetics" using the `AIY (B)` op-code
worked like a charm - much more straight-forward than on the Microtronic!
Like with the Microtronic, "computed" jumps to computed target addresses stored in memory or a register are impossible, so I require the same "jump block" mechanism for the Science Fair as well.
Unfortunately, I ran out of program space on the Science Fair - I would have needed exactly 15 more nibbles! My program overlaps with the data region (from 0x50 on) that I would need for the (value and return) stack - but in principle, the ideas are sound, and it should work (if I only had more space...)
But here is the program so far:
// CONCLUSIONS - DOESN'T HAVE ENOUGH MEMORY :-(
// JUMP BLOCK OVERLAPS DATA REGION (50... )
// Towers of HANOI on the Science Fair Microcomputer Trainer
// (C) 2024 by LambdaMikel
// Memory and registers need to be set up manually:
// 1. Load n = 1, 2, 3, 4 into B (@ 6C)
// 2. Point Y (@ 6E) to 53
// 3. Load Label 0 into 53
// 4. Set up first stack frame by hand:
// 50 = SOURCE : A
// 51 = DEST : C
// 52 = SPARE : B
// 53 = RET : 0
// MoveTower(n, source, dest, spare)
00 2 CH GET n value from B: A <- B
01 C CIA 1 A <> 1 ? -> FLAG = 1, JUMP REC. CASE
02 F JUMP REC CASE @ OB - JUMP executed when FLAG = 1 (A <> 1)
03 0
04 B
// A = 1
// Base case
// Y points to RET label
// move disk from source to dest
// no mem space for output! only n display
05 1 A0 HEX DISP
06 2 CH Store n value back into B: A -> B
07 F JUMP JUMP BLOCK @ 50
08 5
09 0
// A > 1
// Recursive case
// Compute n - 1 by adding F (= Sub 1)
0A 9 AIA F (= SUB 1)
0B F
0C 2 CH Store A = n-1 into B: A -> B
// Prepare first recursive call:
// MoveTower(disk-1, source, spare, dest)
// Stack:
// <50, 51, 52, 53>
// Y points to 53
// SOURCE <- SOURCE
// DEST <- SPARE
// SPARE <- DEST
// Subtract 1 from Y, 53 -> 52
// Load A with cur. SPARE (= 52)
0D B AIY Y <- Y + F (= Y - 1)
0E F
0F 5 MA A <- M(Y = 52 = SPARE)
// Store cur. SPARE into new DEST (55 = 52 + 3)
// DEST <- SPARE
10 B AIY Y <- Y + 3
11 3
12 4 AM A -> M(Y = 52 + 3 = 55)
// SPARE (56) <- DEST (51)
// FROM 55 to 51: SUB 4 = ADD C
13 B AIY Y <- Y + C (= -4)
14 C
15 5 MA A <- M(Y = 51 = DEST)
// Store cur. DEST into new SPARE (56 = 51 + 5)
16 B AIY Y <- Y + 5
17 5
18 4 AM A -> M(Y = 51 + 5 = 56)
// Load cur. SOURCE (50) into new SOURCE (54)
19 B AIY Y <- Y + A (= -6)
1A A
1B 5 MA A <- M(Y = 56 - 6 = 50)
// Store cur. SOURCE into new SOURCE (54 = 50 + 4)
1C B AIY Y <- Y + 4
1D 4
1E 4 AM A -> M(Y = 50 + 4 = 54)
// Set up new RET label 1 (1 -> @ 57 = JUMP to 28)
1F B AIY Y <- Y + 3 (57 = 54 + 3)
20 3
21 8 TIA 1
"Decle" wrote the following interesting comment on my second Science Fair video:
@decle • 7 hours ago The virtual machine and monitor within the SFMT code is implemented in about 1K (the other 1K of memory is used for the 6 built in games). It's really very impressive when you look at the disassembly. Although the TMS1100 has 128 nibbles of RAM, only 80 are available for you program code. There rest is used for the internal state of the virtual machine. 16 nibbles are used for the data memory available to your code. 10 nibbles are reserved for the virtual machine registers and the rest is used to record state like key presses, hex output values etc.
I think he is probably referring to the ROM bits that have been read out by Sean Riddle:
