Materials and tools used in this project:
- Plywood 3.0mm
- American walnut veneer 2.5mm
- Cherry veneer 2.5mm
- Screws 1.5 x 5mm
- Natural mineral Oil: cleaned flaxseed or Belinka Oil (food contact)
- Adhesive tape
- Titebond 2 (dark), Titebond 3 (white)
- Hot Glue
- Dark Varnish
- esp32 controller board x1
- WS2812b Addressable LED strip x108
- TTP223 touch sensor x2
- INMP441 microphone module x1
- USB-C connector (male) x1
- Colored wires
- DIY Laser cutter/engraver 520x520mm, 5.5w
- Eccentric sander
WLED Project: https://kno.wled.ge
iOS App: https://apps.apple.com/us/app/wled-native/id6446207239
Android App: https://play.google.com/store/apps/details?id=ca.cgagnier.wlednativeandroid&hl=en&gl=US
* WLED Guide (if your LED strip won't work from 3.3V data level): https://kno.wled.ge/basics/getting-started
** Increase or decrease the Maximum Current Value dependent on your Power Supply,. The default value of 800mA should be enough for a good start ;)
*** WLED API https://kno.wled.ge/interfaces/http-api
Midjourney Prompt: alchemy gothic, for wood laser cut, square, vector line art, 2D [vector, flat, 2d, simplified, black and white, no background] --v 5
Software used:
Prototyping: OnShape https://www.onshape.com
Desktop Vector Editor: Inkscape https://inkscape.org
Tablet Vector Editor: Curve https://www.linearity.io/curve
AI Image Upscaler: Upscayl https://www.upscayl.org
Timber Rough
trax
mkdxdx
Steve Pomeroy
