Background processing of videos
06/18/2024 at 22:55 • 0 comments -
Many mics
06/11/2024 at 08:28 • 0 commentsToday was a good day (Ice Cube)
Tested these mics
Not really "tested" I plugged em and recorded video
There were so many good shots mmm the light was good
It's not segfault it's not segfault ohhhh....
05/23/2024 at 05:09 • 0 commentsyeah... been getting this lately
I think it's pyaudio but haven't pinned down the reason
I went to a nice park as a result of the local one being closed, it was a great decision that place is way bigger though farther away but still not a bad drive
Today was an amazing day at a park I hadn't been to before, I can feel my arms still burning ha I was in the sun for so long
The segfault stuff kept happening but the systemd service would restart itself and the video/audio merge in general was fine
This camera runs ffmpeg
05/22/2024 at 05:20 • 0 commentsFew USB-related updates
Finally... don't have to sync external mics
Supports USB mic (at least 1, Lavalier) audio merged into mp4 video from h264
Also added mass storage transfer (don't have to use SFTP eg. FileZilla)
And with Delete All Files again don't have to SSH into it to remove files
Videos and PRs
Arducam 8-50mm and future video camera
05/20/2024 at 17:14 • 0 commentsThe ml-hat-cam's gearing was beefy, so I gotta make it smaller, control all rings (3) and add linear stabilization (x-y).
It'll be hard because the cantilevered load (heavy lens/steppers)
16mm day out at park and feature dev
05/15/2024 at 04:29 • 0 commentsI'm starting to envision the next stage as I use this camera more and more
More cameras...
For some reason the color yellow... is in my mind
And a flip display/camcorder style plus sliding rail stabilizer for the lens so videos look better... may make more sense to have an outside/full body gimbal but still. Because the sensor one also has to hold up lenses attached to it.
Oh yeah the other thing is small steppers that autofocus the lens. I've done some work with that (laplace).
Arducam 35mm
05/12/2024 at 02:57 • 0 commentsI need to do some kind of stabilization in the future, the 1080P video is pretty usable
The vibration is brutal particularly on the higher mm lens
Lot of sample footage 1080P 30FPS 5mm 12mm 35mm CCTV lenses
05/08/2024 at 00:43 • 0 commentsReally like this shot mmm
There were a lot of snakes out I saw at least 4
Video Record Live View
05/07/2024 at 01:14 • 0 commentsIdk what to call this but it's what cameras normally have ha, where you can see what you're recording.
Another day out
04/17/2024 at 20:03 • 0 commentsI got some better shots
I have some code in progress now, not sure if I'll get it done today/soon.
Will address:
- USB file transfer (no wifi network needed eg. sftp)
- delete all camera/video files from menu choice
- reset battery from menu choice (vs. current percentage check)
Jacob David C Cunningham
