A little Fishy
06/29/2017 at 11:42 • 0 commentsHere's a shot of a custom strip that I made for a fellow member of the Texas Maker's Guild to aide when he's demonstrating his aquaponics setup. The firmware is written so that it's just alway's on, there's no motion sensor or button installed. 3D-printed end caps double as braces to start it up off the tank a little bit.
Kits now available on Tindie!
03/14/2017 at 01:44 • 0 comments -
Added STL files for light strip assembly
03/10/2017 at 13:05 • 0 commentsAttached 3 stl files for the end caps that clean up the ends of the Under-Cabinet light strips and drill jigs for drilling the aluminum bits to build up the assembly.
Created first draft of light strip assembly instructions
03/04/2017 at 20:21 • 0 commentsUploaded a pdf of assembly instructions to build this board into a motion-activated under-cabinet LED light strip. I'm open to any feedback on how to improve this.
Link to firmware on GitHub
02/10/2017 at 03:03 • 0 comments -
Board Overview
02/08/2017 at 05:42 • 0 comments -
2' LED strip assembly video
02/07/2017 at 12:57 • 0 commentsInstructions for assembling this controller into a 2' motion-activated LED strip.
Now on Tindie!
02/07/2017 at 12:52 • 0 commentsThis project is now available on Tindie here: https://www.tindie.com/products/rogera/motion-activated-led-driver/
Soon to come will be a kit with all required parts to put together an under-cabinet motion-activated power LED strip.
roger_archibald
