GSPro sockets interface working (at least on test platform)
A project log for PiTrac - The DIY Golf Launch Monitor
Launch monitor using low-cost Raspberry pi and camera hardware to determine ball launch speed, angles and spin
james-pilgrimJames Pilgrim 03/23/2024 at 22:320 Comments
A simulated GSPro launch monitor interface and test sockets server is now complete.  The server simulates an actual GSPro Connect system in order for me to be able to do end-to-end testing.  This LM interface send results data to the GSPro socket whenever a ball is hit.  I don’t actually have a real GSPro system yet - still need to rummage around for a sufficiently modern graphics card and build a machine to run that.
An example JSON object that was sent from the launch monitor to the simulated GSPro server (and the simulated response) is shown below.  Hopefully I can validate on a real system soon.  The only thing I can see wrong at this point is that the spin angle is somehow being truncated to 0.  Probably a dopey radians/degree mistake on my part.
[2024-03-23 16:18:46.440414] (0x0000007fb2794040) [trace] Received the following message from the Launch Monitor:
    "DeviceID": "PTrac LM 0.1",
    "Units": "Yards",
    "ShotNumber": 1,
    "APIversion": "1",
    "BallData": {
        "Speed": 31.0,
        "SpinAxis": 0.0,
        "TotalSpin": 0.0,
        "BackSpin": 3743.0,
        "SideSpin": "-358.0",
        "HLA": 13.3,
        "VLA": "-7.9"
    "ClubData": {
        "Speed": 0.0,
        "AngleOfAttack": 0.0,
        "FaceToTarget": 0.0,
        "Lie": 0.0,
        "Loft": 0.0,
        "Path": 0.0,
        "SpeedAtImpact": 0.0,
        "VerticalFaceImpact": 0.0,
        "HorizontalFaceImpact": 0.0,
        "ClosureRate": 0.0
    "ShotDataOptions": {
        "ContainsBallData": true,
        "ContainsClubData": false,
        "LaunchMonitorIsReady": true,
        "LaunchMonitorBallDetected": true,
        "IsHeartBeat": false
[2024-03-23 16:18:46.441129] (0x0000007fb2794040) [trace] Sending the following message from the GSPro simulated server:
        "Code": 201,
        "Message" : "GSPro Player Information",
        "Player" : {
           "Handed": "RH",
           "Club" : "DR"
