Vento is a SunLeaf derivative board that replaces the ESP-09 modules with a ESP32 chip. The idea behind Vento is that its a BLE and ARM development platform that can run off lipo batteries and be solar charged.
Its essentially a more open ended SunLeaf as far as applications go, where as SunLeaf is aiming to be a node in a remote sensor network.
Vento will allow individuals to make bluetooth or wifi enabled devices of their own using the same technology as SunLeaf.
AVR
What kind of solar panel do you recommend for this design? Looking forward to seeing more!
