This package contains a number of files needed to get your Arduino installation and Mozzi library ready to compile sketches for the Atmega 644pa in your Macchiato. Find setup instructions in the Macchiato Quick Start Guide and Reference Manual.
x-zip-compressed -
188.40 kB -
01/30/2017 at 15:55
This is the compiled hex file that comes ready on the Macchiato. You should have this file on hand before you start messing around with programming. If you ruin your Macchiato, or if you are unable to get Arduino to compile for the 644pa, you can always flash this file back onto your Macchiato to restore it to original condition.
