The pictures have the Schematics.
Replace your old alarm system panel with a new board with up to 42 zones that will integrate with Home Assistant
MainAlarmPanel.yamlYAML file for ESP Home inside of Home Assistantyaml - 10.50 kB - 03/28/2024 at 14:36 |
Thanks for sharing nice information with us. https://mp3juicee.download
Do you intend to publish your code? I just added the .yaml file for ESPHome to the project.https://sawmandsalah.com/
@Ira Schonfeld - I use Home Assistant for all of my home automation. Inside of Home Assistant there is an integration with ESPHome which controls ESP32 based devices via .yaml code. In a nutshell, ESPHome installs the ESPHome firmware on to your ESP32 devices and then there is a .yaml file for each device...
@Ira Schonfeld - I just added the .yaml file for ESPHome to the project
Hmmm. not what I was expecting - what environment runs .yaml code? Thanks
Wow, excellent project and design. Do you intend to publish your code? Thanks.
Is it possible to get gerber files for this PCB?
