The case was designed for a 9" mini keyboard and 8.8" strip display, and was printed and sprayed with industrial yellow paint. Found a suitable 10000mAh battery that can be installed in 2 pieces at the back of the keyboard with a total capacity of 20000mAh inside the case. The next step is to integrate the keyboard PCB and battery PCB and modify the shell to add a rotatable bracket.
ElecLab
