The program of the RISC-V CH582 chip has already started running initially, and the USB keyboard can run normally and stably when connected to the Raspberry Pi and PC. The length of the ElecLab 8.8-inch display can fit well with the 9-inch MINI keyboard, but the size will still be relatively small. We may need a longer screen and a normal keyboard to fit it. After searching, I found that the 11.26" display screen can match the length of the key core.
ElecLab
pcadic
Richard
Max.K
bobricius
