5.4V 5A output test, because the 5A current produces a voltage drop on the USB test line, and there is still 5.1V on the instrument.
Welded the newly arrived 10K B3950 NTC resistor to the PCB and attached it to two batteries to monitor the battery temperature.
ElecLab
