IM BACK!
12/25/2024 at 05:47 • 0 commentsHello Hackaday!
With the release of the Compute Module 5, Modufix is being redesigned.
With a new thermal design and new accessories solution, Modufix will be better than ever!
Hope to see you all again very soon in 2025!
I am moving..
06/14/2024 at 05:37 • 0 commentsOver to Reddit, as much as i like hackaday i will be moving logs and other information over to reddit, come join r/modufix to learn more!
Pro Camera Backplate Underway
05/29/2024 at 03:12 • 0 commentsThe HQ Camera Backplate is underway to be released with Modufix. This backplate has a HQ camera module from Raspberry Pi that has a C/CS Mount for lenses.
This Backplate will have a grip on the left side of the device.
Almost Done
04/11/2024 at 23:26 • 0 commentsWe are very close to fully releasing Modufix
Cellular - 4G or 5G?
03/28/2024 at 20:57 • 0 commentsThe question of 4G or 5G has been brought up in design, and i have decided to use a design based on Sixfab's design (https://sixfab.com/product/raspberry-pi-base-hat-3g-4g-lte-minipcie-cards/.)
Unfortunately the design does not support 5G, but i may be able to make a simmer design with 5G.
Pi Zero Support End Of Life
03/24/2024 at 04:12 • 0 commentsUnfortunately I had to cancel plans to be able to use a Pi Zero with Modufix. I had to do this as the limited capabilities the zero has at the moment, with only 512MB of ram it would have been impossible to port android to it. Also getting a display to work with HDMI was also going to be a challenge for a sub $200 display. I know this may be bad for some people who already had a pi zero on hand to start the project, but without it version 6 and onwards will have a much cleaner and better design.
- Shambler
