Oh, I see... ABCD are connected to GPIOs, as is the transistor-base...
So when the transistor-base (column?) is high, you're scanning the right-side of switches, and when it's low, you're scanning the left-side? So you're saving a column-GPIO. Cool!
Ah hah! Thought I was 'bouts to learn a new trick ;)
FYI, I think it would've worked, I've recently discovered that transistors can work both ways, "reverse-active mode," where the C and E are swapped. You get the same effect, but much less current-gain.
Noo, not from me :) but I might have done something like that and wouldn't even have noticed it then? Gotta check... dupdid'oh. Hm, seems like I have in fact mixed up connector and emitter in hardware.
I take it ABCD are resistors of different values? Am confused, how's this work? (Don't take that wrong, BJTs are still a bit of black-magic to me).
They're just pulldowns for the row signal. I only safed one pin, not 4 ;)
Hahaha, this doesn't help...
Does it work?
it almost works : ) not sure what's happening with row A atm, it toggles ON OFF on the OFF side. So it works 87.5% of the time... :D
Probably not related to your 87% problem, but what's the rationale behind tying the emitter to the switches, rather than V+?
I might have mixed up collector and emitter while drawing, I tend to forget what I see within 2 seconds or so :D you're right, they are.
Edited it, thanks!
Haha, maybe better mixing up the E and C than inserting an NPN where you intended a PNP... that can be *really* confusing ;)
But you can't make new part footprints from scratch!
But I could scratch the footprints..
