Is it alright to say DaveCAD?
A project log for 433MHz MQTT remote
with the oh so popular ESP12 of course!
davedarkodavedarko • 01/21/2017 at 20:45•11 Comments
the button matrix
Eric Hertz wrote 01/23/2017 at 00:53 • point
I take it ABCD are resistors of different values? Am confused, how's this work? (Don't take that wrong, BJTs are still a bit of black-magic to me).
davedarko wrote 01/23/2017 at 07:04 • point
They're just pulldowns for the row signal. I only safed one pin, not 4 ;)
Eric Hertz wrote 01/23/2017 at 10:27 • point
Hahaha, this doesn't help...
Oh, I see... ABCD are connected to GPIOs, as is the transistor-base...
So when the transistor-base (column?) is high, you're scanning the right-side of switches, and when it's low, you're scanning the left-side? So you're saving a column-GPIO. Cool!
Does it work?
davedarko wrote 01/23/2017 at 11:50 • point
it almost works : ) not sure what's happening with row A atm, it toggles ON OFF on the OFF side. So it works 87.5% of the time... :D
Eric Hertz wrote 01/23/2017 at 12:06 • point
Probably not related to your 87% problem, but what's the rationale behind tying the emitter to the switches, rather than V+?
davedarko wrote 01/23/2017 at 12:18 • point
I might have mixed up collector and emitter while drawing, I tend to forget what I see within 2 seconds or so :D you're right, they are.
Edited it, thanks!
Eric Hertz wrote 01/23/2017 at 14:26 • point
Ah hah! Thought I was 'bouts to learn a new trick ;)
FYI, I think it would've worked, I've recently discovered that transistors can work both ways, "reverse-active mode," where the C and E are swapped. You get the same effect, but much less current-gain.
davedarko wrote 01/23/2017 at 15:18 • point
Noo, not from me :) but I might have done something like that and wouldn't even have noticed it then? Gotta check... dupdid'oh. Hm, seems like I have in fact mixed up connector and emitter in hardware.
Eric Hertz wrote 01/24/2017 at 08:30 • point
Haha, maybe better mixing up the E and C than inserting an NPN where you intended a PNP... that can be *really* confusing ;)
deʃhipu wrote 01/22/2017 at 11:23 • point
But you can't make new part footprints from scratch!
davedarko wrote 01/22/2017 at 13:11 • point
But I could scratch the footprints..
