Advanced-Ultimate-Box-Maker-EL.scadOpenSCAD code to make EL box. You will need to install OpenSCAD and the Advanced Ulimate Box Maker support files. Look for the install instructions for that on Thingiverse.com. If you don't wish to make changes to the box then the .stl files are all you need.scad - 72.25 kB - 12/03/2024 at 23:36 |
ELBoxTop.stlTop Shell of box.Standard Tesselated Geometry - 699.11 kB - 12/03/2024 at 23:35 |
ELBoxBottom.stlBottom shell of box with fan opening and holes for PCB mounts and feet.Standard Tesselated Geometry - 1.03 MB - 12/03/2024 at 23:35 |
ELBoxBackPanel.stlBack Panel of box with fan hole mounts and hole for barrel jackStandard Tesselated Geometry - 350.08 kB - 12/03/2024 at 23:34 |
Bud Bennett
