We are using 4 seringes that are on a plateform next to the installation, They are linked to 4 other seringes. It can activate 3 rotation an a grabing action.
We've first started to assemble all wood pieces together for the arm. Then we had to assembly the syringes, it was difficult because space was limited and because syringes didn't stay in place. We managed to assembly the arm. We've then assembly the pinch and add it to our project. However the pinch is heavy and so is adding too much weight on the arm and so the pressure in the syringe is not enough. Unfortunately the arm can't stay up for long because of that. We should have made the arm pieces longer so we could have a counterweight. We also had an issue with the syringes because syringes were leaking a bit so air could fit inside and messing up our synergies position.
Finally after assembling the arm we needed to make it hydro so we filled the seringues and tubes with water. After having a problem with air in the tubes we succeed in making it work as we wanted.
We took a wood board to fix the 4 actions seringues to help practicability.
The pinch was ready and it was time for the presentation.
Now that we had the dimensions for each piece we needed to laser cut them. So we did the work with Fusion 360 and then on Inskape to obtain the necessary pieces. We did them in wood with a 3mm thickness. We got our components together and time was up for this time. For The wood parts, we had to cut 16 pieces of wood. 2 of 20cm*20cm, two of 8.5cm*8.5cm with a 0.5 hole in the middle. two of 13.5cm*13.5cm, two of 20cm*4cm two pf 26cm*4cm. And the diamond with it's claws.
search for components, we wanted to calculate the size and volume for our seringues. we found our tubes and implemented our sketchs and found the right dimensions.
finally we ended up choosing 10ml seringues, perfect for the delta angles we wanted.
We've started the prototype the arm, we search for syringe and cable dimensions. We also have done the bare bones for the laser cutting of our final pieces.
