Currently 2 assembled devices haven been successfully tested on a Landis+Gyr E450 Smartmeter and a ISKRAEMECO AM550 Smartmeter.
The complete setup allows to read energy usage in short intervals (15 seconds by default), transmit them via UART to a Canique Smartmeter Sense (a radio transmitter based on https://hackaday.io/project/186949-canique-ambience), which then parses them and sends them via 868MHz to a base station.
The big differences between this design and available products on the market are:
- No necessity for a power outlet. The energy meter adapter will be powered by the Canique Smartmeter Sense, which itself is powered by a standard AA battery.
- Good wall penetration and range. Unlike WiFi this radio setup can easily go through mutliple walls.
- Extremely low power. A single AA battery will be able to supply the sensor + IR adapter for multiple years. The expected total quiescent current for the sensor + IR adapter from a 1.5V battery is: 2.57µA
canique
mrozo
Scott
Rusty Jehangir
