It has been over half a year since the last keyboard project was released, and it's high time for some adjustments and improvements.
With the popularity and widespread use of 3D printing, I have redesigned the appearance to minimize unnecessary supports during the printing process, making it easier to print. The color scheme can be freely customized to present an even better effect.
We plan to support two different shapes of screens: rectangular and circular.
For the code, we plan to start updating from CircuitPython 9.x, while also supporting other frameworks such as Arduino and MicroPython.
To facilitate production and assembly, the circuit board has been simplified by removing redundant components and reducing the number of PCBs to just one. Additionally, some circuit modifications have been made, but the relevant pins remain compatible with previous designs.
Thanks to the updates of the CircuitPython library Adafruit_CircuitPython_ImageLoad, it is now possible to use PNG images with transparency and add background images.
I'm using resin 3D printing and spraying paint to see how it turns out.
I've just discovered an interesting project, and I also want to try porting it over. It's very easy, so let's see how we can play the dino game on this project.
In this Arduino project, an interpreter that was new to me was used. Hopefully, there will be opportunities to use it to implement some fun ideas in the future.
I've developed a small game designed to assess an individual's temporal perception skills, specifically focusing on the precision of second estimations and their awareness of the passage of time. The programming required for this game is quite straightforward. Upon pressing a key, a timer begins. The objective is to release the key when you believe the pre-determined time interval has passed. By analyzing the outcomes, we can evaluate a person's aptitude in perceiving time accurately.
The primary programming used for development is CircuitPython.
CircuitPython is an open-source firmware for microcontrollers that makes it easy to program hardware with Python. It's particularly popular for educational purposes and hobbyist projects because of its simplicity and the large community supporting it.
The image demonstrates an attempt at gauging 4 seconds of time passage. Ha!
from magiclick import MagiClick
import os,displayio,supervisor,gc,terminalio
import rtc
import time
from adafruit_display_text import label
import board,microcontroller
mc = MagiClick()
from adafruit_bitmap_font import bitmap_font
font_file = "fonts/LeagueSpartan-Bold-16.bdf"
font = bitmap_font.load_font(font_file)
# font = terminalio.FONT
main_group = displayio.Group()
mc.display.root_group=main_group
t_label = label.Label(terminalio.FONT, color=0x2f88ff, scale=3)
t_label.anchor_point = (0.5, 0.5)
t_label.anchored_position = (mc.display.width//2, mc.display.height//2)
t_label.text = "Press"
main_group.append(t_label)
mc.display.auto_refresh=False
mc.display.refresh()
microcontroller.cpu.frequency=160000000
mc.display.brightness = 1.0
now = 0whileTrue:
time.sleep(0.001)
key_event = mc.keys.events.get()
if key_event:
if key_event.pressed:
key = key_event.key_number
elif key_event.released:
key = key_event.key_number+10else:
key=-1if key==0:
now = time.monotonic()
t_label.text="Timing"
print("Timing")
elif key == 10:
t = time.monotonic()-now
t_label.text= f'{t:.3f}'
print("end")
print(t)
elif key==2:
print('exit')
microcontroller.cpu.frequency=240000000
mc.exit()
Drawing inspiration from the C language implementation of tinyflap, I successfully developed a Flappy Bird game utilizing CircuitPython. The debugging phase proved to be unexpectedly seamless, enabling me to swiftly create an initial prototype of the game.
The ground and clouds were drawn using the adafruit_display_shapes lib, whereas the bird and pipes were implemented directly using images.
Primarily, I wish to sincerely thank PCBWay, a leading entity in the industry, for its perceptive vision in identifying the potential of my project and extending substantial backing. Your sponsorship has transcended material provision by equipping me with superior-grade, precision-crafted PCB products that have been instrumental in facilitating seamless advancement during the R&D process.
Throughout our cooperative engagement, the dedicated technical team at PCBWay has upheld a stringent attitude and provided efficient services, guaranteeing faultless precision at each juncture, thereby significantly boosting my operational efficiency. The outstanding product quality and considerate customer service you deliver have undoubtedly been crucial factors contributing to achieving key developmental milestones in the project.
The testing process has been largely smooth, during which we did identify a minor design oversight where the LDO (Low Drop-Out) section was not provided with a stable control signal, leading to an inability to completely shut down the system. However, this issue is relatively easy to rectify; it can be resolved by shorting two pins as indicated in the diagram. Currently, we are using CircuitPython version 8.x and have confirmed its successful operation. In the coming days, I will commence work on porting to version 9.x.
A charging indicator LED has been integrated onboard, facilitating the observation of the charging status.
