Based on previous experience, after the schematic diagram was ready, the first version has finally been updated.
The pcb has been checked and found to be without issues, so it's ready for sampling.
The components with small packages have been chosen as much as possible on the PCB, therefore, only one side needs to be soldered.
MakerM0
