- Push buttons will connect to GPIOs
- Joysticks are 2 axis potentiometers, will connect via ADC-I2C
- Screen could use I2C to keep it simple, will only be receiving data, might use SPI
- **UART used to program ESP32
- Modules:
- Power supply
- Motion control
- uC & Bluetooth
- Mode change
CH340 USB to UART- will be attached to the underside of the PCB
- USB - bottom layer
- UART - bottom layer ->via -> top layer
- Other stuff:
- On-of switch
- Indicator LEDs (power, BT connected, data Tx, data Rx)
- Emergency stop?
- How to you implement a remote E-stop
- Battery holder and terminals
- Voltage levels, 3.3V for everything, maybe 5V - leaning towards the former
- Should be able to connect to external
