Hackaday.io Hackaday.io
Sign up Log in
SurvBot
Remote controlled robot that surveys the environment it is travelling in. PCBs for the Robot and Remote Controller will be original designs
ghani-lawalGhani Lawal
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
484 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 26
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
882
0
484
2
Team (1)
  • ghani-lawalGhani Lawal
Join this project's team
  • SurvBot
hardware
ongoing project
STM32 kicad Embedded pcb
This project was created on 04/02/2024 and last updated a year ago.
Description
Part One - Robot Control Unit (RCU)
- Design and implement a PCB that has closed-loop control over 2 DC motors
- Monitors and saves data about itself and the environment it is in:
- Current flowing though the motors
- Ambient temperature
- Ambient light
- Humidity
- Orientation (or just the tilt angle, TBD)
- Possess Bluetooth communication
- Entire system is powered by a 9V-12V battery
- Can connect to computer via USB2 2.0 to load the data saved on the PCB
Project Logs
Collapse
  • SurvBot - Remote Controller - START PART2
    Ghani Lawal • 10/02/2024 at 22:06 • 0 comments
    • Push buttons will connect to GPIOs
    • Joysticks are 2 axis potentiometers, will connect via ADC-I2C
      • https://www.digikey.ca/en/products/filter/joystick-potentiometers/82?s=N4IgTCBcDaIFYHsCeBnALgSwMYGsQF0BfIA
      • Leaning towards "PS2 like thumb joysticks"
        • https://www.digikey.ca/en/products/detail/sparkfun-electronics/COM-09032/6823623
        • https://www.sparkfun.com/products/9032
    • Screen could use I2C to keep it simple, will only be receiving data, might use SPI
    • **UART used to program ESP32
    • Modules:
      • Power supply
      • Motion control
      • uC & Bluetooth
      • Mode change
    • CH340 USB to UART
      • will be attached to the underside of the PCB
      • USB - bottom layer
      • UART - bottom layer ->via -> top layer
    • Other stuff:
      • On-of switch
      • Indicator LEDs (power, BT connected, data Tx, data Rx)
      • Emergency stop?
        • How to you implement a remote E-stop
      • Battery holder and terminals
      • Voltage levels, 3.3V for everything, maybe 5V - leaning towards the former
        • Should be able to connect to external
  • SurvBot - Remote Controller - START PART1
    Ghani Lawal • 10/02/2024 at 21:51 • 0 comments
    • Requirements:
      • Send/receive messages over Bluetooth - ESP32
      • Control robot's velocity and direction - Joystick most likely
      • Place robot in different modes and itself in different modes - push-buttons
      • Display relevant information, can choose what it displayed and how it is displayed - screen and push buttons
      • Battery powered - BT takes a lot of power
      • Programmable via USB  - use a USB to UART converter
      • Simple to use IDE - Arduino
    • Will take inspiration from game controllers and RC controllers
      • https://www.amazon.ca/FLYSKY-Transmitter-Controller-Receiver-Upgrade/dp/B07Z8VCB45/ref=asc_df_B07Z8VCB45/?tag=googleshopc0c-20&linkCode=df0&hvadid=706841688476&hvpos=&hvnetw=g&hvrand=1694029161074720460&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9001024&hvtargid=pla-1088447909254&psc=1&mcid=c9f926f34897300eaa7c25e74dbb2f04&gad_source=1
      • https://www.amazon.ca/DJI-FPV-Remote-Controller-Compatibility/dp/B0CS6JCX2W/ref=asc_df_B0CS6JCX2W/?tag=googleshopc0c-20&linkCode=df0&hvadid=706724959887&hvpos=&hvnetw=g&hvrand=1694029161074720460&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9001024&hvtargid=pla-2489520640472&psc=1&mcid=f32a5bfd8b8c3bf7bbd4d2b5bef1abd8&gad_source=1
      • https://www.google.com/search?sca_esv=5de61c6dbcae3990&rlz=1C1CHBF_enCA862CA864&sxsrf=ADLYWIJSQK7JbUN--RXnojvIJRHf0_mpcA:1727902305618&q=ps2+controller&udm=2&fbs=AEQNm0CrHVBV9axs7YmgJiq-TjYc7RgyMjmhctvLCnk5YpVfOzTk9UgrCkq1LL6wECoQ_WGpuh2-yvh4a1uIS1ER30dB5AWZ8RxNjUsmzFd4N_UT1oUNZfs4C3G8xLBj8dMjxnxwyU-UJN99U7fNsRI-pWnVE5KFVJFgLI_Oh0CZhjHwc1W0HeIrcIvNwyjxFJw-UaUn9lCRGxP3O_xa89hyqWrDJSrVcw&sa=X&ved=2ahUKEwis84fZyfCIAxUQmIkEHc_SLPsQtKgLegQIEhAB&biw=1920&bih=919&dpr=1#vhid=Lb2cas9fS-k0YM&vssid=mosaic
  • SurvBot RCU Altium Designer
    Ghani Lawal • 09/18/2024 at 20:50 • 0 comments
    • Finished Schematic and PCB in Altium Designer
    • Made custom symbols and footprints
  • SurvBot PCB
    Ghani Lawal • 09/04/2024 at 22:06 • 0 comments
    • Finished SurvBot PCB in KiCad
    • Used JLC7628 stackup
  • Current draw of motors
    Ghani Lawal • 08/10/2024 at 21:10 • 0 comments
    • Tested Motor Under no load at 6V, experimentally determined that:
      • Max speed < 180 rpm
      • Max current draw < 400mA
    • Stalled Current (held motor in place while it tried to rotated at max speed)
      • < 1.5 A
      • ***May have damaged motor, no longer rotated perfectly along axis
  • External Memory
    Ghani Lawal • 08/10/2024 at 21:03 • 0 comments
    • Requirements:
      • store at least 1MB, don't need more than 10MB
      • SPI interface
      • Vdd = 3.3V
      • Recording temperature, orientation/tilt, light, current, commands
    • Temperature, humidity and light: 1 sample/second
    • Orientation, current, commands and speed: 10 samples/second
    • Temperature and humidity from SHT30-DIS & light from ADPDS are each 2 bytes
      • 6 bytes * 1 sample/second = 6 bytes/second
      • 360 bytes/minute
      • 21600 bytes/hour
    • ADC is 12-bit, will store as 2 bytes each for left motor and right motor -> 4 bytes
    • Orientation sensor: roll pitch and yaw - 2 bytes each -> 6 bytes
    • Commands: speed and direction - 2 bytes each -> 4 bytes
      • 14 bytes * 10 samples/s = 140 bytes/second
      • 8400 bytes/min
      • 504 000 bytes/hour
    • Total: 525600 bytes/hour, stored raw this is about half a MB per hour
    • Couldn't find an EEPROM
    • Using NOR flash IC SST26VF032BT-104I/SM: 32Mbit
  • Motor Drive Unit Power
    Ghani Lawal • 08/04/2024 at 16:07 • 0 comments
    • Planning on powering entire device from 9V battery (unregulated supply), motor drive unit needs a 6V regulator
    • Encoder operating voltage is 4.5 to 7.5V
    • ***Even though STM32G0B1CE has 5V tolerant pins that are used for encoder input, the output voltage of the encoder will likely match the operating voltage
      • Will either use level shifters IC's or voltage dividers resistors, leaning towards the latter
    • Since motor is rated for 6V and that is within encoder operating voltage, will use the same IC to power both
      • LM2576S-Adj, I_MAX = 3A
      • Has tips on picking out all the external circuitry and lays out a design procedure as well
  • Power Budget and Power Circuitry
    Ghani Lawal • 08/04/2024 at 15:37 • 0 comments
    • Made a "worst case scenario" power budget, this was made on July 29th,
      • Absolute max current draw by microcontroller is 100mA, but typical supply current is under 10mA, and adding peripherals only adds a 10s of uA
      • This is important because the efficiency of the buck converter under different current loads is dependent on the Inductor value, large loads -> small inductor, small loads -> large inductor
      • Therefore, want to figure out "typical" current draw before deciding on inductor values for regulators
  • Power From USB
    Ghani Lawal • 08/04/2024 at 15:17 • 0 comments
    • Can be quite noisy, use a pi filter to filter out noise
    • Set up CC pins on USB_C receptacle to get 500mA from source
    • ***** If inductor has no DC resistance, circuity will essentially be a resonator -> give sharp peak at corner frequency instead of trailing off
    • With ESR = 0.15 ohm, the corner frequency is 1MHz, don't want to dampen below that because ICs sometime need high-frequency currents
  • USB Application Notes TA0357 & AN4875
    Ghani Lawal • 08/04/2024 at 15:11 • 0 comments
    • TA0357: Overview of USB Type C and Power Deliver Tech.
      • 2 Configuration channels (CC) for the discovery, configuration and management of USB Type C Power delivery features
      • A sink must assert Rd pull-down resistors on both CC pins
      • USB 2.0: Nominal voltage of 5V, max current of 500mA
    • AN4878: Introduction to USB hardware and PCB Guidelines for STM32
      • Protection against ESD and EMI:
        • The "HBM" require that USB pins of component device be tolerant p to 2kV of discharge
        • Low Price: USBLC6-2SC6 (+ ESDA7P60-1U1M for VBUS)
        • Low Area: USBLC6-2P6 ((+ ESDA7P60-1U1M for VBUS)
      • VBUS Sensing:
        • A USB device must have VBUS sensing detection based on the USB specification
        • When the device detects the host's presence it connects its pull-up resistor to either a D+ or D- data signal line, this allows the host to detect the device presence on the bus
        • 1) If the USB device is bus powered, USB sensing isn't mandatory (USB is always connected with device is powered)
        • 2) Device is self powered - VBUS sensing is mandatory
        • ************* Not all STM32 microcontrollers that have USB peripherals have dedicated sensing pins
          • If they do, it is usually - PA9 additional functions: OTG_FS_VBUS
        • ************* The embedded pull up resistor on D+ pin in STM32G0B1CE is used for USB device detection
View all 26 project logs
Log In/Sign up to comment
Sign up with Github
OR
Ultra-compact flight controller for mini quadcopters, based on RP2350B MCU.
Project Owner Contributor
RP2350B Flight controller
vitaly-kornilovVitaly Kornilov
My version of the ubiquitous USB serial port gizmo
FTDI-be-gone
nick-sayerNick Sayer
Measure voltage, current & power from any USB-C charger with an OLED meter or a Wi-Fi logger – both fully open source.
DIY USB-C PD Tools: Power Meter & Wi-Fi Logger
ludwinLudwin
Pocket-sized 240W lab supply! Leverages USB-PD 3.1 EPR for adjustable 48V/5A output.
PD240W
theo-hengTheo Heng
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "SurvBot", please tell us the reason.
Send message
Remove Member
