- Can be quite noisy, use a pi filter to filter out noise
- Set up CC pins on USB_C receptacle to get 500mA from source
- ***** If inductor has no DC resistance, circuity will essentially be a resonator -> give sharp peak at corner frequency instead of trailing off
- With ESR = 0.15 ohm, the corner frequency is 1MHz, don't want to dampen below that because ICs sometime need high-frequency currents
Ghani Lawal
