1How to solder a FlexiBall?
Here are the details of soldering and assembling a FlexiBall.
2Solder LEDs
There are four WS2812B-2020 LEDs on the front side. Make sure the orientation of each LED is correct. FPC connector should be on the another side of the PCB.
Tip: Flexible PCB is different from rigid FR4. The usual third-hand is not recommended because its teeth of clips makes dents on flexible PCB. Use one PCB holder or wise without too much force so that the flexible PCB is just held there without moving or bending.
3Solder two flexible PCBs together
After the LEDs are soldered, it is natural to connect two PCBs together.
Each PCB has three connection port. There are one input with a label of "I" and two outputs with a label of "O". There is a small gap on each connection port. Put two PCB as the above before soldering.
There are two cases of soldering. One is just to solder two connection ports on the FPC side only like the below. These are only ground on the FPC side.
Another case is to solder solder the connection port on both LED side and FPC side. It is to connect both power and signal (on LED side) and ground (on FPC side). Below is one example.
4Overall assembly diagram and some details on signals
Given the above information, if you have a multimeter, it would be pretty easy to decipher all the signals. The triangle has three sides. One side has the input. The other two sides have the output. The top side is the LED side and the bottom side is the FPC side.
Use the dash-line triangle above as the base unit, below is the overall assembly diagram. The green number in each triangle is the order of assembly. The blue line is the signal lines. Start with the first triangle, test it with your LED controller board. The connect the second, test again. The first five triangles will make a pentagon shape.
Solder to connect the blob only if they are in the blue-line connections.
Happy assembling a flexiball!
ndGarage
