Hardware:
- 8x DS5180 SSG Digital servo (80kg)
- 8x DS servo disk (8 threaded holes)
- 24x 8x5x2.5 bearing (MR85ZZ)
- 5mm 304 stainless steel shaft
- 4 x 3 custom length cuts
- 28x M3 self tapping screws (15mm)
- 16x M2 self tapping screws (12mm)
- 16x M4 hex bolts (20mm) + 16 x nut
Filament:
- PETG (tested)
- print settings (Voron standard)
Assembly level (challenging)
Interesting indeed, original designs is only printable with a (DOD) 3D Printer cause of the 0.2mm used tolerances
