• Step 3: Result
    Makerfabs • 04/09/2024 at 01:51 • 0 comments
    The platform begin to move when I open the HA_MOTER DC Motern and stop automatically when it touch the terminal at the edge.
    And when I click the HA_MOTER DC Moter, on the pop-up page, I can control the platform direction of movement and speed of movement.
  • Step 2: Device Configuration
    Makerfabs • 04/09/2024 at 01:50 • 0 comments
  • Step 1: Assembly
    Makerfabs • 04/09/2024 at 01:49 • 0 comments
    1.Install the printout on the slide rail
    2.Install the 2 collision switches for position limiting on the printout
    3.Install the DC Motor for Home Assistant_GA36Y-555 on the printout
    4.Install the GT2 Timing Pulley on the DC Motor for Home Assistant_GA36Y-555
    5.Install the Idler Pulley wheel on the printout
    • Note that Idler Pulley wheel and GT2 Timing Pulley should be parallel to slide rail.
    6.Pass the belt through the slide gap and around the idler and timing pulleys, securing it to V-Slot Gantry Kit - 20mm
  • Supplies
    Makerfabs • 04/09/2024 at 01:48 • 0 comments
    1.V-Slot Gantry Kit - 20mm
    2.Idler Pulley wheel
    3.GT2 Timing Pulley
    4.GT2 Belts
    5.V-SloT Linear Rail
    6.Assembly Hardware
    • All of the above components can be found in Openbuilds.
    7.Some components need to be printed by BambuLab printer,the 3d file you can click Here.
    8.DC Motor for Home Assistant_GA36Y-555
    9.AC/DC adaptor
