1.Install the printout on the slide rail
2.Install the 2 collision switches for position limiting on the printout
3.Install the DC Motor for Home Assistant_GA36Y-555 on the printout
4.Install the GT2 Timing Pulley on the DC Motor for Home Assistant_GA36Y-555
5.Install the Idler Pulley wheel on the printout
- Note that Idler Pulley wheel and GT2 Timing Pulley should be parallel to slide rail.
6.Pass the belt through the slide gap and around the idler and timing pulleys, securing it to V-Slot Gantry Kit - 20mm
