Imagine a full light transistor . With the base collector emitter working simultaneously as a light valve, This valve will work on light, letting it pass through or not, it will depend if the gate is charged.
the idea is to create a way to switch on or off a structure based on silicon that can enable light to pass through or hold it and spread as a light bulb.
Now imagine a bunch of this micro phototransistors inside a glass . Using lasers we may be able to switch the transistors and with other laser rgb we will be able to make the color appears where we want.
maildodanillo
Lisa Taylor
trax
Guillermo Perez Guillen
Anteneh Gashaw
