1Download the STL files & Print
2Adding weld nuts
3Assembly the circle display with M3 screws
4Set & assembly the PI3
5Input the battery
Use double-sided tape to keep it from moving in the gap
6Carry out all pre-assembly of the elements.
7Prepare the entire power supply section with a soldering iron and connect the speaker and HDMI cables.
8Clone the MicroSD of 32Gb and input in PI3
Unzip with 7z and clone with Balena for example
https://www.7-zip.org/download.html
Telegram group with the image SWAP ARCADE
9Assembly and screw all the parts together once their operation has been tested.
10Input the Lens
SrRubio
