Protean 8x2: 16-Ch N/P FET Power Control
A 16-Ch N/P FET power node/controller, wired, interfaced, programmed, & addressed your way to bridge the gap of power & microcontrollers.
The Protean 8x2 is an Arduino compatible development board with power control in mind. It gives you the freedom to use the FETs, (essentially DC power switches), and connectors you want. You can determine the full turn-on voltage most efficient for your FETs, (the Vgs), without hunting for “logic-level” FETs. Because it has a place for optocouplers to provide electrical isolation, you don’t need to worry that it will fry the ATmega328P micro-controller.
Kickstarter HERE!:
https://www.kickstarter.com/projects/939637926/1475517171?token=f2811508
This started as a project to develop a pinball driver node, nevertheless, it can be used for quite a variety of other power projects, such as:
• 8x8 bulb or high power LED matrix controller
• LED lighting controller
• Irrigation controller
• Automated compost barrel
Etc
What’s the story behind it?
I posted some 6-segment LED display concepts on DeviantArt and a fellow named Andrew showed strong interest in it as a pinball score display. (Something I hope to pursue later!) He also linked me to his 2015 Ohio Pinball Show gallery on Facebook. This got me interested, and a couple months later my dad and I visited the Lone Star Pinball Museum.
Enamored with all the various pinball machines, I had developed more interest in the art, design, and mechanics of pinball machines. Later I noticed someone commissioning an artist for pinball plastics art on deviantART! The next thing I did was look for pinball parts or some general purpose hardware that was ideal to control such a machine. But I was surprised by what I found, and didn’t find.
The Search for Power Control
I love the idea of node based controllers seen in modern pinball machines, but nearly all of them are proprietary and virtually undocumented! The hardware available for custom machines run about ~$100+ per board, are generally large (~20 sq in./~130 sq cm), require a separate main controller, and have a fixed serial protocol and rate. Other boards were understandably meant for use in existing, typically older machines, and were more expensive.
From the “build your own” perspective, there were numerous Audrino FET shields to chose form, (and relay boards), but all with different specs, hardware interfaces/terminals, and limited FETs. Of course they also required a separate Arduino or controller board.
Many people just use an Arduino Mega and run wires to multiple different modules and components. The same could be done with the awesome Teensy 3.5/3.6, (an ideal main controller for pinball in my opinion). But the otherwise tedious point-to-point or expanded board-to-board method didn’t seem very appealing, easily scalable, or space conscious. There’s already enough unavoidable connections to be made.
Building the Answer
With FETs being the common denominator in most of my projects, after trying to find a flexible driver node solution, it struck me. Why not develop a node board that’s configurable by the designer, not only in protocol and function, but also in choosing wiring connectors and FETs?
The “General Purpose N-Ch FET Driver Board Node” was born and evolved into the Protean 710, then to the Protean 8X2 supporting N and/or P channel FETs! It’s the size of two Arduino Unos, just about the same board area as a Stern driver node, but more independent power outputs. It’s also a third smaller than other available boards with similar output counts.
(Debug and power test unit with debug LEDs using the Protean 8x2 prototype V1 with V1.2 and V1.3 mods.)
With an abundance of processor and IoT devices out there, it’s my hope to bring the power hardware side of things more up to speed in versatility and flexibility, filling the void between power control and microcontrollers. While I won’t dare claim the Protean 8x2 completely fills that void, I honestly think it greatly helps!
Code/Software can be found here: https://github.com/adamlhumphreys/Protean8x2-C
  • 16 × RC0402FR-07100KL Resistors (Fixed) / Thick Film Surface Mount
  • 35 × ERJ-2GEJ561X Electronic Components / Misc. Electronic Components
  • 2 × RC0402FR-0710KL Resistors (Fixed) / Thick Film Surface Mount
  • 2 × CC0402JRNPO9BN180 Capacitors / Ceramic
  • 5 × MC0603B104K250CT Capacitors / Ceramic
View all 11 components
View all 2 project logs
Simon wrote 02/19/2017 at 19:58 point
Hi Adam,
Nice idea with this project, I like especialy that this board has support for Wi-FI ESP8266.
Br, Simon.
Adam L. Humphreys wrote 01/24/2017 at 09:23 point
Open Questions for the Kickstarter!
• You can always change it, but what should be the default baud rate? Right now I’ve been testing it at 2Mbps.
• What SMT jumpers should be set by default? I figure I should leave the POE jumpers alone for those who want to use wireless modules in the breakout pins. My thoughts are to set the lower 8 channels ready for N-channel FETs. Or should I set all channels to be ready for N-channel FETs by default? Thoughts?
• Should I include optocouplers on the board as a stretch goal, and if so, how many? Board variants? I ask this because if anyone intended to use the header pins as inputs, the optocoupler would be reduced to a pull-down resistor, also meaning the input could only be active high unless the optocoupler or series resistor was removed.
