1Controller Board Case
Paper prototype
CAD model for controller board case
3D printing controller board case
Final 3D printed case (with soldered battery holders and header pins)
Final 3D printed case with lid
2Push Buttons for Cat Legs
CAD model for button case
Cross section view of CAD model Solder 2 female jumper wires to push button
Push button inside 3D printed case
Push buttons with cap and 3D printed lid
3Cat Tail
Wrap wire around back of lamp PCB board
Braid wire along length of ribbon cable
Crochet tail to fit lamp PCB board, ribbon cable, and wire
4Cat Body
Crochet body to fit around 3D printed controller board case
5Assembly
Sew legs, tail, and ears to body
Controller board is accessible from the bottom
Case with cover
Final cat lamp!
6Coding
Accelerometer: controls LED color based on tilt
Left paw push button: controls LED brightness
Right paw push button: toggles LED color mode (tilt or fixed color)
