1Step 1
2Step 2
Solder the control and buttons
3Step 3
Assemble the model and wire the rest of the circuit. All assembly is with plastic and silicone glue
4Step 4
Load the .ino program on the arduino to turn it into a xinput command
5Step 5
Setup MAME
The configuration used for the screen is the following
When you have the Arduino and controls connected, we have to configure it within the menu. Input/External Controller/Define Keys
Program path to add to the ROMs folder
6Step 6
And finally. We print the arcade arts on adhesive paper
SrRubio
