Hackaday.io Hackaday.io
Sign up Log in
DIY Two Step/Anti Lag for turbo/launch control
Goal is to make a two step rev limiter with anti-lag in order to spool the turbo on my truck quickly for launch.
daniel-johnsonDaniel Johnson
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
7.8k views
3 comments
24 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 2
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 3
View Gallery
7.8k
3
24
9
Team (1)
  • daniel-johnsonDaniel Johnson
Join this project's team
hardware
ongoing project
Software
antilag turbo two step nitrous engine tuning performance ECU ECM pcm v8 ls
This project was created on 01/24/2017 and last updated 5 years ago.
Description
This design uses an atemga328p to create a two step/anti-lag/launch control system by using one port of the atmega to take the inputs to the coils from the ecm and another port to output signal to the coils. this way each individual cylinder can be controlled. One of the timers measures the time between ignition events from the ECU in order to calculate RPM and compares it with a setting that is configured over wifi. It has the ability to shift the igntion event by 1 cylinder to achieve anti-lag (on 8 cylinder cars this achieves 90 degrees retarded timing).
Files
W39728ASR12_WiFi-TwoStepV5-GERBER.zip
PCB Gerbers
Zip Archive - 113.16 kB - 08/05/2021 at 00:07
Download
Wifi Two-Step.zip
Software
Zip Archive - 788.62 kB - 08/04/2021 at 23:56
Download
Components
  • 1 × atmega328p
  • 1 × ESP8266
Project Logs
Collapse
  • Update using atmega328p instead of attiny85.
    Daniel Johnson • 01/24/2017 at 18:50 • 0 comments
    a quick update where i talk about why the previous plan would not work and also show the new plan.
  • Overview of project.
    Daniel Johnson • 01/24/2017 at 18:48 • 0 comments
    At the time of this video i had a different plan utilizing an attiny85 which would have resulted in erratic spark behavior which could be bad for the engine.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Chris Zhu wrote 08/05/2021 at 05:43 • point
Have you considered getting RPM data from the OBD2 port? I recently built a small device to get a bunch of ECU stats from the OBD2 port with a standalone atmega328p soldered on protoboard and it's been working great for a few months so far -- and its pretty cheap, only around ~15 bucks in parts. Just get a generic ELM327 OBD2 scanner on amazon that has a UART based bluetooth module inside, desolder the bluetooth and connect tx/rx to the 328p...pretty elegant solution and you don't have to deal with reading ignition events to estimate RPM, which might slow down the loop time especially if you're reading that through interrupts
Daniel Johnson wrote 08/05/2021 at 23:21 • point
I have been asked this a few times, It wouldn't be hard to use OBD2 to grab the RPM, but it is fairly easy to count the time between the previous and current ignition event and use that to calculate RPM. In fact i am pretty sure this would be much faster and more accurate than grabbing it from OBD2. The code is dead simple for the atmega328p.
Chris Zhu wrote 08/06/2021 at 00:09 • point
Fair point, I guess that makes sense. Looking forward to more updates!
Use an Arduino to sync as many media players or DVD players as you want.
Project Owner Contributor
IRremoteSync
lumbriclumbric
Official Hackaday Prize Entry
Real racing in a real world
FULLMETAL RACER
frederico-sobreiraFrederico Sobreira
Miscellaneous hacks to help my daughter's life with cerebral palsy be just a little easier.
Heather Accessibility Project
karl-bielefeldtKarl Bielefeldt
2021 Hackaday Prize
WFH results in a lot of time spent with your kids... maybe too much time. The solution is to shoot them with a FPV Nerf Quadcopter
FPV Nerf Quadcopter
coryCory
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "DIY Two Step/Anti Lag for turbo/launch control", please tell us the reason.
Send message
Remove Member
