There were some issues getting the WIFI to work using the default rpi-imager path. I had to use an ethernet cable to connect to the pi and run `sudo nmtui` to set up the WIFI connection.
I proceeded to install all necessary applications using kiauh
Installing Klipper on the Manta M8P
I'm using the guide provided here
cd klipper
make menuconfigproduced an error regarding an unsupported locale. I tried setting my locale with
sudo raspi-configbut that did not fix the error. export LC_ALL=C
export LC_ALL=Cdid seem to fix the error.
The rest of the documentation seems fine and got me to a working install. Printer is reporting errors, but that's because it's not configured yet.
E/S Pronk
