- Remote controller : in order to control the drone
- Nano receiver : Made to receive the inputs of the remote controller
- Flight controller : Drone's central brain, stabilizing and managing the aircraft. It processes sensor data and user commands to adjust motor speeds and control surfaces, ensuring stable and responsive flight.
- Electronic Speed Controller (ESC) : Regulates the speed of the drone's motors. It receives signals from the flight controller and adjusts the power supplied to each motor, ensuring precise control and stability during flight.
We also had the parts that our teacher lent us :
- Motors
- Propeller
With all of this, we needed just only one thing that will create a link between all of this parts : the Frame.
Like you saw in the other Project Log, the Frame is almost designed. We just need to confirm that the dimensions are good and that we can print it.
We also need to know how to program our Flight Controller. We will do that during the week so that we can hopefully finish the whole drone next week !
