Just adding this here so it is part of my "collection" of hacks. Sourcecode and writeup can be found here:
https://github.com/cpldcpu/BitNetPDK
https://cpldcpu.com/2024/05/02/machine-learning-mnist-inference-on-the-3-cent-microcontroller/
MNIST Neural Network Inference on a 3 cent Microcontroller
Of couse, the basic arithmetic element would just be an accumulator and some multiplexers or xor gates. What is a bit more complex, is how to get all the data in. But you could start small and use a microcontroller to do the shuffling.
Also, analog neurons could be made the same way.
Well, I am working on a TTL + uPD7220 video card, and getting all the data in is a big task there. For sure, there are good ways to load the inputs or strobe the weights - it is a similar issue, at least if you care about speed. What may be really interesting is making it both forward propagate and learn - although I'm sure this is also much more difficult. Anyway - thank you for sharing your project, it is really cool, as well as inspiring.
Hmm, you're making me wonder: maybe this could be done also with TTL logic, without too much hassle? Seems like it could be an interesting project.
